20 Most Recent Proform 650 Crosstrainer Treadmill Questions & Answers
2answers
The incline on my proform treadmill is not working
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or
thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
4.
If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced. It is possible the console is not giving the proper signal but we've never seen it happen in thousands of treadmills.
8/10/2022 4:43:32 PM • Proform 650... • Answered on Aug 10, 2022
I have a Pro-form 650 Cardio CrossTrainer. All of
Normailly there are 2 system: 1) Manual, see the belt if there are defective,try to put a Little LUBE it,since has a LOT of mechanical stress. Replace it if Necessary. 2) The small motor in the system, can be faulty or broken, replace it.However test the batteries if the system have, clean the contacts batterys, with special liquid clean contacts cleaner, and tight very well the connector, and clean too. Blessing. [email protected] cell+whatsAPP:+50588611441
11/3/2017 3:20:38 PM • Proform 650... • Answered on Nov 03, 2017
0answers
0answers
Treadmill turns on but turns itself off
This may be a problem with the LCB.
12/4/2013 1:27:44 PM • Proform 650... • Answered on Dec 04, 2013
What is the power source for the display console
you must see the schematic diagram coming with your treadmill, or read your owner manual, and follow the instruction in section assembly or parts manualGod bless you
11/1/2013 11:29:03 AM • Proform 650... • Answered on Nov 01, 2013
Elliptical manual
download from www.fitness.manualsonline.com for freeGod bless you
7/27/2013 4:56:43 AM • Proform 650... • Answered on Jul 27, 2013
User manual for proform 650 crosstrainer
i get no power to unit is there a reset or fuse?
7/23/2013 1:59:36 PM • Proform 650... • Answered on Jul 23, 2013
0answers
0answers
Proform 650 Crosstrainer Treadmill Logo
55 questions posted
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Proform Exercise & Fitness
Most Popular Question
treadmill belt keeps slipping cannot
  • Exercise & Fitness
