20 Most Recent Stairmaster 4400CL Stepper Questions & Answers
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
If the battery tests low, you can recharge by using the machine or using the proper voltage charger. These are 6 volt batteries, so you will need a charge with a 6 volt capability. Once charged, let the battery set overnight. If it remains charged then you should be able to use the battery without issue. If it drains overnight, chances are, you have a dead cell and the battery will need to be replaced with a new one. Battery 6 Volt Stairmaster SM14123 SPORTSMITH net
Stairmaster... | Answered on Sep 29, 2015
Sportsmith of course, we have your power supply in stock :) http://www.sportsmith.net/productsearch.aspx?dsNav=N:11167 If you find you need anything else please do not hesitate to call us at 888-713-2880 or chat with us online :) we look forward to hearing from you.
Stairmaster... | Answered on Aug 25, 2015
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
This can cause a clunking sound. For the replacement parts, please see the link below.
Why does one Pedal Drop on my Stairmaster Stepper
Stairmaster... | Answered on Feb 11, 2015
This link will take you to the parts listed for the 4400CL:
Stairmaster Stepper 4400CL Parts Spring Chain Battery SPORTSMITH net
Right above where is shows the number of results found, there are 3 tabs: "products" "manuals" and "diagrams".
Stairmaster... | Answered on Nov 12, 2014
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
Corrective Action
Stairmaster... | Answered on Jul 31, 2014
Use our support center.
SPORTSMITH LLC
Stairmaster... | Answered on Jul 15, 2014
SPORTSMITH LLC
See our support center for all your Stairmaster questions.
Corrective Action
Start with verifying the voltage output from your battery. The video below will show how to do this.
http://www.sportsmith.net/ Click on your model number for access to an owners and service manual. The below link will also take you directly to the battery for your machine. Battery 6 Volt Stairmaster SM14123 SPORTSMITH net
The charger input is located on the users left, at the very bottom of the machine. This link will take you to a picture of the Left cover. If you look at the image, you will see a small hole in the bottom. This is where your power inlet will be located.
Lower Left Panel SM27058 06 SPORTSMITH net
Stairmaster... | Answered on Jun 19, 2014
Stairmaster... | Answered on May 21, 2014
Use this link to go to our Website and obtain a user manual and an owners manual by clicking on the manuals tab in the middle of the screen.
Stairmaster... | Answered on May 20, 2014
Corrective Action
Stairmaster 4400CL Stepper Logo
Popular Tags
44 questions posted
Top Stairmaster Exercise & Fitness Experts
Vernon Taylor
ray gallant
Tom Chichester
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Stairmaster Exercise & Fitness
Most Popular Question
configuration ford
  • Exercise & Fitness
