20 Most Recent DeLonghi DSM7 Stand Mixer Questions & Answers
take it in to an appliance repair shop for a proper diagnosis and quote but it is probably not worth repairing ( armature and brushes )
DeLonghi DSM7... | Answered on Apr 09, 2017
I had the same problem and fixed it.
  1. I took it apart, unplug unit, remove the small black cover inside the stand portion, 1 screw. Underneath you will find four screws with a white plastic wire junction.
  2. Loosen two screws and remove the black and brown wires which connect to the control panel with the dial attached.
  3. Remove rear attachment cover, front top cover, and front delonghi cover.
  4. Remove top three screws where the blender attachment goes. Now remove the aluminum cover that covers the entire top.
  5. Slip belt off. Remove three screws with plastic washers that attach motor to chassis.
  6. Remove 2 torx screws that are located next to metal bar that keeps top half from swinging too far from bottom half.
  7. Now you can pull the motor out and the control panel with the dial. Remove the three slip on electrical connections on the control panel and reinstall. Carefully remove the two slip on electrical connections on the motor and reinstall.
  8. Re-assemble and test unit.
I thought I had a problem with the control panel or the motor, as it turns out the connections were the problem. Carefully removing them and reinstalling them solved the problem.
DeLonghi DSM7... | Answered on Feb 16, 2010
its not a problem at all and has no issues,thats common. you can use it without any hassles.nothing to be done for this.
----- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
DeLonghi DSM7... | Answered on Jan 02, 2010
type delonghi in the search bar. Pick a site and yell at them. Kidding, tell them your problem and they should work with you. Get a phone number and call them, get the salesmans name and a time frame you can expect repacements.
DeLonghi DSM7... | Answered on Oct 28, 2009
Ask at the following link, I found there most of parts for DSM7 mixer.
http://www.forumappliances.com/
Good Luck
DeLonghi DSM7... | Answered on Nov 02, 2008
There should be a overload breaker on the bottom of the motor, tilt it back and look for a little red (probably) button.  other than that, there shouldn't be anything else... if it doesn't  work, it might be defective... Don't give up hope though, those mixers, (used to be Rival, and made by Kenwood in europe) are *SOO* much better than Kitchenaid, it's not even funny *Grin* and good luck.
DeLonghi DSM7... | Answered on Aug 09, 2008
Contact Cooks Essentials directly to inquire.
Food Mixers | Answered on Jul 04, 2020
Hi guys,
The only available Kitchen Aid stand mixers on the European markets are the Kitchen Aid Classic and the Kitchen Aid Artisan.
The best way is to contact a Kitchen Aid service center / repair facility in your area.
Here is the European website of Kitchen Aid: http://www.kitchenaid.eu/eu_EU/ka/ka_europe.htm
If you bought a different Kitchen Aid Stand Mixer (like the Professional series) you probably won't find the required parts to convert it to a European model. The only way would be to use a voltage converter.
I hope this helps.
Food Mixers | Answered on Jun 30, 2020
EVER PUT GREASE IN IT
Food Mixers | Answered on Jun 11, 2020
You can buy a new mixer from Amazon or Martha Stewart
Chef's Mark 650WT Stand Mixer, Red - Martha Stewart
www.marthastewart.com > shop > chefs-mark-chefs-mark-650wt-stan...
A powerful stand mixer is a must-have kitchen essential. This standout performer includes a meat grinder, flat beater, dough hook, wire whip and rotor slicer/ ...
Chef's Mark Hand/Stand Mixer : Everything Else - Amazon.com
amazon.com > chefs-mark-hand-stand-mixer
Chef's Mark hand/stand mixer makes every baking and mixing task easier. Classic mixer features 5 speeds plus turbo and pulse. Product information ...
Chef's Mark 4.2-Qt. Stand Mixer with Accessories - Gettington
www.gettington.com > product > NIFZK
Rating: 3.8 - ‎44 reviews - ‎US$152.97 - ‎Out of stock
This powerful Chef's Mark® stand mixer is a must-have kitchen electric essential! 4.2-qt. stainless steel bowl with cover; 10 step-less speeds plus pulse; 650 ...
Chef's Mark Hand/Stand Mixer: Amazon.ca: Home & Kitchen
www.amazon.ca > Chefs-Mark-Hand-Stand-Mixer
Stand mixer with rotating 3.2-qt. stainless steel bowl. Can also be used as hand mixer; 5 speeds plus turbo and pulse functions. Built-in safety features; 4.3-ft.
Food Mixers | Answered on May 23, 2020
Thanks for the clarification
Food Mixers | Answered on May 22, 2020
Specially designed to be equipped with *kitchen machine function *food processor function *blender function *cooker function *fryer function *and more adjustable time from 0 to 90 minutes adjustable speed from 200-9,000RPM adjustable temperature from 40?C-140?C Large 2.5L stainless steel cooking bowl with the bimetal laminated sole Cooking bowl is specially designed to be dish-machine washable safe Patented highly efficient heating devices Patented safety lock device for cooking bowl cover Removable metal steel cutting blade and low speed stir LCD functions display Auto funcion for soup, sauce and jam 600W motor power , 1300W cooking efficiency
Food Mixers | Answered on May 13, 2020
DeLonghi DSM7 Stand Mixer Logo
13 questions posted
Top DeLonghi Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you a DeLonghi Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
  • DeLonghi Food Mixers
Most Popular Question
delonghi dsm7 stand mixer won 39 t
  • Food Mixers
