20 Most Recent
Chase-Durer Blackhawk Mach 3 Alarm Chronograph Questions & Answers
The watch just quit working. I had the battery
go back to whoever replaced battery first ask them to check battery not faulty then if battery ok ask them did they AC the watch when fitting battery any repairer who knows what they are doing will know what you mean, if they dont find a decent repairer..other option have it serviced..
Directions to replace the Blackhawk watch battery.
Exact replacement battery you can find written on the original battery.
Do not mind the manufacturer or the letters, because they can vary. Just make sure you are buying the well known manufacturer battery, e.g. SONY, MAXELL, CEIKO, CITIZEN, RENATA, TOSHIBA, YAMAHA, etc.
The most important thing is to EXACT match of the numbers as they are giving the exact code of the battery.
EXAMPLE: Lets say: your battery have some letters and the number 1616. That means: your battery is 1.6 cm in diameter and 1.6 mm in height (thickness), or: 1.6cmX1.6mm, or simplified 1616.
As I said- do not mind the letters, as different manufcturers are using different letter codes (for quick in-house reference) and these letters have no use for you.
So, if you are ready to follow - open your watch caseback and take the battery out. Write down ALL the letters and numbers of that battery.
If you expierance any difficulties to open the watch - let me know.
Do not forget to rate, please.
Need to replace the watch battery.
All battery driven watches are sensitive, not just the Chase-Durer.
Even the cheap ones, as the movement can be damaged or destroyed by the static electricity (touch of the bare finger).
Extra care is not needed to replace your watch battery, just you have to follow some simple, but very basic rules.
If you are ready to do it yourself- let me know and I'll guide you throgh all the steps (by asking me questions on this site).
Ifyou are not, then I'll let you know the best place to do that at nearest shop possible.
Hi, my stop watch runs
Setting date:---
• Unscrew crown counter-clockwise (toward you) to position 0
• Pull crown out to position 1
• Turn crown counter-clockwise* to set date
• Push crown in and screw-in until tight. (clockwise - away
from you)
* NOTE: By turning crown clockwise with crown in position 1,
the alarm hand will move.-----------------------
Setting time:--
• Pull crown out to position 2
• Turn crown to set hour and minute
• Push crown in while screwing-in clockwise. (away from you)
* NOTE: Do not set date between 9 p.m. to 1 a.m
If the above mentioned procedures are not helping to reset the watch then,Try to reset this way,-------
pull the crown all the way to zero in the chronograph second hand, This will also stop the watch itself. Then try to reset the time and see if it helps.
IF CHRONOGRAPH HANDS DO NOT RESET BY PRESSING BUTTON
B while watch is in stopwatch mode, they can be reset manually.
Chronograph Second Hand
• Unscrew crown
• Pull crown to Position 2
• Push Button A until hand is reset to proper place
Chronograph 1/20 Second Hand
• Unscrew crown
• Push Button B until hand is reset to proper place
This should help.Thanks.Helpmech.
Problems setting and understanding sub
Very difficult to explain this without a model name or number of the watch. Is it a Conquest, a Pilot, a Starburst, a Squadron Commander, a Xanadu?
Please specify the model of the watch and which sub-dials you are having difficulty with. Do you have the instructions and are unable to understand them? Our answer can only be as good as your question. The more details you provide, the more comprehensive the answer will be.
Regards,
BElectric.
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM •
Watches
Answered
on Apr 07, 2024
