20 Most Recent
Daisy Winchester 1000B Synthetic Stock Break Barrel Air Rifle Questions & Answers
I have a winchester 1000
sounds like there is an obstruction between the barrel and the firing chamber.try cleaning the barrel and the chamber. If this does not work make sure when you place the barrel in the firing position that everything is lining up correctly allowing for an efficient release of air from the chamber.
Pellet gun will not fire
If its your first time using it, make sure the bolt is pulled back before pumping it. Pulling back the bolt resets the sear and drops the valve.
If its well used, either your pump head o-ring or valve has gone bad.
