20 Most Recent LG 55LS4500 55 in. TV Questions & Answers
Your TV may have some feature such as simulated surround sound enabled. Return to the initial set up procedure and check.
LG 55LS4500 55... | Answered on Jun 12, 2017
BUENAS SERIA BUENO Q REVISARA EL CIRCUITO DE ILUMINACI?N DELA PANTALLA DE TU TV EMPIEZA POR AH? PARECE SER UN PROBLEMA DE SOBRECALENTAMIENTO SI TU TV ES PLASMA YO TU IRIA A POR LOS IC QUE ALIMENTAN LA PANTALLA DE NO SER ASI POR Q EL TV ES DE LED O LCD REVISARIA LAN LAMPARAS Y EL INVERTER EN ESE ORDEN ESPERO Q DES MAS DETALLES PARA AYUDARTE MAS SUERTE
LG 55LS4500 55... | Answered on Mar 01, 2017
Hi Richard, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=Bf5T2wwtydY
LG No Picture Screen Flash 47LN5200 47LN5400 47LA6200 47LN5700 47LN5750...
LG 55LS4500 55... | Answered on May 03, 2016
If you have checked power supply bar and the TV power plug are both working in normal order, then you need to send in the technician for fixing the TV, may be the fuse was burnt out etc.
LG 55LS4500 55... | Answered on Jul 26, 2014
If you know how to access the region code, then I suggest you give it the code for "0" then you will not need to change it again. It should play back all.
LG Televison &... | Answered Yesterday
necesito programar un control rca a un dvd speler spdv107
LG Televison &... | Answered 2 days ago
check input connections make sure going to in and check input or source
LG Televison &... | Answered 3 days ago
Make certain that your WIFI settings have not changed. Had same problem once, re-entered WIFI information and it worked.
LG Televison &... | Answered on Jan 14, 2020
LG 55LS4500 55 in. TV Logo
Popular Tags
12 questions posted
Ekse
RONALD CARTER JR
View Most Popular
  • LG Televison & Video
Most Popular Question
lg 55ls4500 after turning tv picture
  • Televison & Video
