20 Most Recent Electrolux EOB5610 Ultrafan Electric Single Oven Questions & Answers
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Electrolux... | Answered on Jun 13, 2011
Only two possible causes. The oven element is faulty or the oven thermostat controller is faulty. Probably the first thing to do is test the oven element and check the resistance. If the element is okay then the oven thermostat will need replacing.
Electrolux... | Answered on Feb 24, 2011
Sounds like you element is faulty. You can check it by removing the panel in front of the element which is held on by 4 screws then you can visually check it to see if it has blown. If it looks ok then unscrew the element and carefully pull it towards you a couple of inches, this will allow you to pull the 2 wires off, make sure the wires dont fall back inside the machine or you will need to remove the back panel. The use a multimeter on the buzzer or sounder setting and place a probe on each of the pins on the element and if it doesn't buzz or sound then the element is faulty. Make sure you have the electric switched off at all times. Hope this helps
Electrolux... | Answered on Feb 23, 2011
You need to change the fan motor. These motors are not very powerful and wear in the bearing can cause this effect. oiling the bearings is only a tempory fix and you will eventually end up changing the motor.
Electrolux... | Answered on Jan 22, 2011
well most peeps put it on 300
Electrolux... | Answered on Dec 25, 2010
If the fan is working o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Electrolux... | Answered on Sep 08, 2009
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Electrolux... | Answered on Jul 08, 2009
Yes, you do have to access from the back side.
Electrolux... | Answered on Feb 14, 2009
usually you have a bake and a convection button if you only one button for baking you may not be able to use bake with out the fan good luck
Electrolux... | Answered on Mar 24, 2008
Hey Luciano, I appreciate your inquiry!
From the information you have provided your Electrolux oven is displaying an error code of F130. I have researched possible error codes and it appears that this error code is invalid. I would recommend performing a reset on your oven and you can do that by unplugging the power cord for roughly ten minutes. If you restore power and continue to receive the error code can you please comment? I would be happy to assist you further. -Matt
Electrolux Ovens | Answered on Jun 02, 2020
this is a error for the touch controls its normally caused by moisture getting on it, theres an upgraded part you can order from electrolux which is basically just a strip of foam you fit under the touch controls to prevent moisture getting in
Electrolux Ovens | Answered on Feb 07, 2020
Your oven may have been damaged by a power surge.
Electrolux Ovens | Answered on Oct 28, 2019
Electrolux EOB5610 Ultrafan Electric Single Oven Logo
Popular Tags
21 questions posted
Top Electrolux Ovens Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Ovens
  • Electrolux Ovens
Most Popular Question
grill works fan works but oven
  • Ovens
