20 Most Recent
473P 3-Button TX Remote Questions & Answers
Ordered correct replacement remotes for
The sequence is as follows: turn the ignition on, press and release valet switch one time. Press and hold valet switch, press lock button on remote. Release valet switch. Test system.
Remote Starter problem
Sounds like the immoblizer bypass is malfunctioning or, the pellet (resistor) in the ignition key itself is wearing down.
Hope you can help. Older
Sounds like you are in "valet mode".
If you can find your model number located on the unit I could be of more help.
But, you can try putting the key in the ignition, turn it to the on position, press the valet button located under the dash, in the glove box, or where ever it is located, and then turn the ignition off and you should be out of valet mode.
How to reset python remote starter
hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this .. im a frequent buyer there since Im a mechanic so take help from there
