20 Most Recent Lenovo IdeaPad Z500 Laptop Computer - 593126U - Dark Chocolate Questions & Answers
Try this:
https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/Z400-Adjusting-the-Brightness-in-Windows-8-1/ta-p/1303113
Lenovo IdeaPad... | Answered on Jul 13, 2015
Hi, I had this problem also and I don't know why, but Lenovo Ideapad Z500 seems to have some compatibilities issues with a new Intel video card.
So, what you need to do is rolling back the HD intel video card driver to the previous version OR go to the following path: D:\drivers\VGA\Intel\x64\9.17.10 and press Setup to install the old driver again.
That solved my problem. It's a shame that I can't upload this driver in my laptop.
Lenovo IdeaPad... | Answered on Apr 11, 2015
You can get an Microsoft Office product key from ### Windows 8.1 key sale *** , it works very simple and fine,you need to search for it from bing.
Lenovo IdeaPad... | Answered on Mar 20, 2015
Hi!
Try not to use anything wet next time, just special tissues with soft chemicals only. And keep laptop switched off while you clean it!
Do following:
  1. Get notebook to service, or next steps:
  2. Download service manual from the internet;
  3. Unscrew two keyboard bolts;
  4. Push tiny screw driver in those two holes;
  5. DO NOT DETACH keyboard immediately, just turn it slowly untill you can see wiring;
  6. check if surfaces on and under the keyboard are clear and dry;
  7. find keyboard wiring;
  8. detach it carefully;
  9. dry the laptop;
  10. check connection and put small wires back again...
Have fun if it is working.
If not - change the keyboard.
Lenovo IdeaPad... | Answered on Mar 12, 2015
The only option is left connect a usb keyboard or use a wireless keyboard.
Lenovo IdeaPad... | Answered on Feb 07, 2014
You need to find out what is lagging. Try http://msdn.microsoft.com/en-us/library/hh162945.aspx
this will show you the culprit!
Lenovo IdeaPad... | Answered on Oct 31, 2013
what operating system is installed on your laptop?
Lenovo IdeaPad... | Answered on Aug 09, 2013
Your LCD screen is dying. The backlights can go over time. Other then try to replace the screen there is not much you can do. You can always run it off an external monitor if you are like most people and use it a desk most of the time anyhow.
Lenovo IdeaPad... | Answered on Jan 12, 2013
The issue of Error Code 0xc0000225 generally occurs when Windows cannot find the system files used for booting, boot configuration data files are being missed or corrupted while accessing any application or system files/programs.
Check The Printer's Connection
Restart Your Device
Make Sure Your Printer is Online
FULL steps in this blog- Error Code 0xc0000225
View the Original blog
Website:-
www.hptechnicalsupportphonenumber.com/blog/fix-hp-stream-notebook-error-code-0xc0000225/
Lenovo IdeaPad... | Answered on Apr 07, 2020
If you bought the Lenovo at a local dealer, take it back to them. If you bought it through an online dealer, I recommend you track down Lenovo customer support.
Lenovo IdeaPad... | Answered on Sep 05, 2019
really why not ask the game maker directly for help with your w10.
here they are right>?
https://www.mygames.com/
so what do THEY say , it is there code, running.
does Tetris fail or just your games, unnamed,
this maker is bad company they take over your PC
why run this crappp? it takes over your browser,
and more, and is bad.
the do not even have minimum system requirement there.
nor support. avoid like the Plague.
Lenovo IdeaPad... | Answered on Jun 30, 2019
Restart your computer & start tapping f/8 immediately and keep tapping until black screen comes up. Use the arrow keys to select safe mode the press enter. It will start up in safe mode in each corner, the icons are all out of shape and a help window will open. Close that window. Then go to: Start, Accessories, System Tools, right click System Restore & send to desk top.(The reason to do that will be to use it easier ANYTIME you have a problem.) Then do a system restore back to a time before you had the problem. That should resolve it. If not you will have to do a Recovery after saving everything you want to keep on a Flash Drive. On start, type recovery & go there & follow directions.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Lenovo IdeaPad... | Answered on Apr 16, 2019
It's a mechanical problem with the wiring and contacts along the edge of the screen. No "fix" except screen replacement.
Lenovo IdeaPad... | Answered on Apr 01, 2019
Sarthak Sharma and Carla Bunis want more answers
there are many ways to EJECT
1: the botton on the try , is marked EJECT
do so>>
2: the tiny hole on front of same tray use unbent paper clip, stuffed in hole and try ejects manually.even drive chassis in hand. by self.
3: windows is this ,not stated,but windows explorer
right click the DRIVE D:>? and click REJECT.
4: in windows, make sure the device manager does not list, the DVD as dead,red/yellow or unknown.
if device manager shows the drive missing or bad you need to get the new driver for it.
so right click the drive (be online) and click update drive.
no full model number stated, 330 is not full. number. so says Lenovo.
btw even a empty tray will eject.
if the disk is cracked or label fell , then only way
2 might work and cleaning the jam by HAND.
if way 2 fails.
only total dismantling the DVD drive can fix it.
true jams are hard work. ok?> physical world deal there.
not one poster here said, the button is dead.
saving this post from going to ALL wAYS it can fail and long.
Lenovo IdeaPad... | Answered on Feb 03, 2019
Lenovo IdeaPad Z500 Laptop Computer - 593126U - Dark Chocolate Logo
35 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
IdeaPad Lenovo
  • IdeaPad Lenovo
Most Popular Question
lenovo z500 screen brightness issue
  • Computers & Internet
