20 Most Recent Lenovo Yoga IdeaPad Ultrabook 13.3" Touch-Screen Laptop - 4GB Memory - Silver Questions & Answers
Hello, I believe you have a problem with the firmware, different factors can give you the same error; I recommend to do a factory reset (remember before to do back up in the external memory or cloud), then if still persist the issue, you can contact the customer services to get more support. https://support.lenovo.com/us/en/?menu-id=Technical_Support
Lenovo Yoga... | Answered on Jan 19, 2019
Check the MUTE setting has not been set on the speakers.
Check the Volume setting, move to a higher volume level.
Try re-installing the Audio driver.
Lenovo Yoga... | Answered on Jul 29, 2016
I would contact Lenovo technical support if I were you. They can fix or replace your system under warranty if need be.
Lenovo Yoga... | Answered on May 22, 2015
Dear Costmer,
Please Followup,
Press Fn Key+ F11 (-), F12(+)
[email protected]
Lenovo Yoga... | Answered on Feb 13, 2015
MAKE ABLSOLUTELY SURE YOU ARE FOLDING IT BACK ON A SMOOTH SOLID SURFACE NOT ON FABRIC OF ANY KIND.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Lenovo Yoga... | Answered on Dec 24, 2014
What happened to you is a good reason not to set this password. Unfortunately there is no user-serviceable way for you to reset this password. See the Password section in the hardware manual on page 24. The suggestion is that you will need to have the system board replaced at your own expense.
http://download.lenovo.com/consumer/mobiles_pub/ideapad_yoga13_hmm_1st_edition_oct_2012_english.pdf
There may be other options to an experienced technician to reset the password after opening your IdeaPad but this is only speculation at this point. Good luck.
Lenovo Yoga... | Answered on Sep 15, 2014
There may be other options open to you including opening your IdeaPad and removing the CMOS battery or using BIOS cracking software if you are able to boot to a CD or USB device. These options may not be feasible to you as they are particularly technical in nature so you may need to find a qualified technician to perform this work if it is even possible. Good luck.
1.Is it new? It may be the best to take it back to the shop under warranty.
2. Try to connect an external monitor to see if you get any image. If you you get image on external monitor, most probably the screen cable is faulty or even the screen itself.
Lenovo Yoga... | Answered on Jul 09, 2014
go to you tube and see the video...
Lenovo Yoga... | Answered on Jun 05, 2013
The issue of Error Code 0xc0000225 generally occurs when Windows cannot find the system files used for booting, boot configuration data files are being missed or corrupted while accessing any application or system files/programs.
Check The Printer's Connection
Restart Your Device
Make Sure Your Printer is Online
FULL steps in this blog- Error Code 0xc0000225
View the Original blog
Website:-
www.hptechnicalsupportphonenumber.com/blog/fix-hp-stream-notebook-error-code-0xc0000225/
Lenovo IdeaPad... | Answered on Apr 07, 2020
If you bought the Lenovo at a local dealer, take it back to them. If you bought it through an online dealer, I recommend you track down Lenovo customer support.
Lenovo IdeaPad... | Answered on Sep 05, 2019
really why not ask the game maker directly for help with your w10.
here they are right>?
https://www.mygames.com/
so what do THEY say , it is there code, running.
does Tetris fail or just your games, unnamed,
this maker is bad company they take over your PC
why run this crappp? it takes over your browser,
and more, and is bad.
the do not even have minimum system requirement there.
nor support. avoid like the Plague.
Lenovo IdeaPad... | Answered on Jun 30, 2019
Restart your computer & start tapping f/8 immediately and keep tapping until black screen comes up. Use the arrow keys to select safe mode the press enter. It will start up in safe mode in each corner, the icons are all out of shape and a help window will open. Close that window. Then go to: Start, Accessories, System Tools, right click System Restore & send to desk top.(The reason to do that will be to use it easier ANYTIME you have a problem.) Then do a system restore back to a time before you had the problem. That should resolve it. If not you will have to do a Recovery after saving everything you want to keep on a Flash Drive. On start, type recovery & go there & follow directions.
Lenovo IdeaPad... | Answered on Apr 16, 2019
It's a mechanical problem with the wiring and contacts along the edge of the screen. No "fix" except screen replacement.
Lenovo IdeaPad... | Answered on Apr 01, 2019
Sarthak Sharma and Carla Bunis want more answers
there are many ways to EJECT
1: the botton on the try , is marked EJECT
do so>>
2: the tiny hole on front of same tray use unbent paper clip, stuffed in hole and try ejects manually.even drive chassis in hand. by self.
3: windows is this ,not stated,but windows explorer
right click the DRIVE D:>? and click REJECT.
4: in windows, make sure the device manager does not list, the DVD as dead,red/yellow or unknown.
if device manager shows the drive missing or bad you need to get the new driver for it.
so right click the drive (be online) and click update drive.
no full model number stated, 330 is not full. number. so says Lenovo.
btw even a empty tray will eject.
if the disk is cracked or label fell , then only way
2 might work and cleaning the jam by HAND.
if way 2 fails.
only total dismantling the DVD drive can fix it.
true jams are hard work. ok?> physical world deal there.
not one poster here said, the button is dead.
saving this post from going to ALL wAYS it can fail and long.
Lenovo IdeaPad... | Answered on Feb 03, 2019
Lenovo Yoga IdeaPad Ultrabook 13.3" Touch-Screen Laptop - 4GB Memory - Silver Logo
17 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
IdeaPad Lenovo
  • IdeaPad Lenovo
Most Popular Question
screen keeps messing up lines breaks
  • Computers & Internet
