20 Most Recent Toshiba HDNB120XKEG1 Canvio Personal Cloud Questions & Answers
It's possible u may have forgotten ur password its a human thing that we forget our passwords if the site allows u may use the forgot password form and fill it out and regain access to ur cloud account
Toshiba... | Answered on Apr 26, 2014
check your hard drive. is it connected or not. mostly it is observed that boot able device is not connected with computer or laptop. please check it.
Toshiba... | Answered 21 hours ago
If you have Toshiba error code 0xc0000225 in Windows 10 so all you need is patients because it's not a big deal. It occurs when the appropriate computer is not attached or can not be reached. It normally happens when the system becomes overloaded & important system files to start missing. This error issue is sometimes attributed to the fact that the BIOS is not completely ACPI compliant. Out of this Error Code 0xc0000225 Windows 7, boot selection failed because the appropriate computer is unavailable.
Easy Hacks To Troubleshoot Toshiba Error Code 0xc0000225 in window 10:-
Method 1: Have A Look At Your System Files And Disk Files
Firstly, run a system file check and disk check. It is possible that you are getting the Error Code 0xc0000225 just because of your corrupted system files or infected disk file. So, scan them first and fix the bug.
Method 2: Run The Troubleshooter
If you are getting this type of error code then all you need is to run the troubleshooter. Your problem may be fixed after this step. Go to the control panel and run the troubleshooting process.
Method 3: Check Your Hardware
You should check the hardware to fix the bug. You have to unplug all your external hardware and restart your computer to check the hardware. The bug will be fixed.
Method 4: Reboot your PC
Reboot your PC when you are getting so many error codes. After rebooting your system, infected files will be removed and your error code will be fixed.
Method 5: Try To Rebuilt Your System BCD
You should try to rebuild your system BCD from the command prompt to get rid of the error code.
Hope this article helps you to resolve the system issue. If not then there is something wrong with your internal software. Now, all you need is our expert solution. Try to connect with our Toshiba support to resolve the matter by our experts.
Source URL: Toshiba Error Code 0xc0000225 in Windows 10
Toshiba... | Answered 24 hours ago
Error Code 0xc0000185 regularly appears beside the report: The boot form data for your PC is missing or contains errors. Unhappily, if you unplug the USB devices from your Windows machine and reboot your operating system you will still keep getting this error code.
Solutions of Error Code 0xc0000185:-
1: Reboot Your PC.
2: Repair the BCD with an Installation Media Disk.
3: Setup the Hard Drive.
4: Run CHKDSK.
5: System Restore.
FULL Blog with Expert advice- Error Code 0xc0000185
Here is a way to fix any errors in Printer & Computer.
Just follow the steps which are mention on the blog to fix the Error Code 0xc0000185 or Call us the number is given in Blog.
Toshiba... | Answered on Sep 25, 2020
https://www.bing.com/search?pc=COSP&ptag=N12005D082019A2ABA1046C3&form=CONBDF&conlogo=CT3210127&q=resolve+scan+file+storage+error
Toshiba... | Answered on Sep 23, 2020
- The Error code 0xc0000225, means that Windows cannot find the required System Files to boot, or cannot verify the digital signature of a recently installed device driver or application.
The 0xc0000225 error (Your PC needs to be repaired) may happen at the following cases:
  • The computer was turned off, during a Windows Update
  • You have installed an unsigned driver or program.
  • During upgrading Windows (e.g. from Windows 7 to Windows 8 or 10)
  • After cloning or resizing the OS hard disk.
The easiest way is to press F8 at boot up and choose repair.
Toshiba... | Answered on Sep 21, 2020
Log in and go to my account
Netflix
https://www.netflix.com/ChangePlan
Forgot your email or password? Sign In. Remember me. Login with Facebook. New to Netflix? Sign up now. Questions? Call 1-866-579-7172 · Gift Card Terms ...
How do I change my plan? - Netflix Help Center
https://help.netflix.com/en/node/22 If you want to upgrade or downgrade your Netflix streaming or DVD (US only) plan, use this article to guide you through the process.
Netflix Streaming Plans - Netflix Help Center
https://help.netflix.com/en/node/24926 To see current plan pricing and sign up for Netflix, visit Netflix.com/GetStarted. If you are already a member, you can change or upgrade your plan anytime from ...
upgrade Netflix Google Search
Toshiba... | Answered on Sep 04, 2020
LAPTOP made long ago 2009. and cant not be upgraded for GPU !
great question, and 99% of laptops NO.
Toshiba mode support here
https://support.dynabook.com/support/driversOSResults?freeText=2523308
see that ATI chip there soldered down
ATI Radeon 4100
no socket there it is soldered down.!!
so is NO answer simple as can be.
THERE IS NO GPU UPGRADES NOR SLOTS OR CARDS HERE.
that is what you get on low end cheap PC<.
ASK how to get better one.
see your motherboard, see no cards there and all soldered down. forever.
there is no magic x16 PCI-express slot here next time buy a real desktop and get X16 slot, as all gamers use today.
buy Desktop ask for one that is used and cheap
I can point fingers easy, no axe or commission for me.
Toshiba... | Answered on Aug 31, 2020
If your laptop has TPM you won't be able to do a reset without a service center. It's part of keeping laptops secure.
Hi, Tracy you can do a password reset for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.iseepassword.com/forgot-my-toshiba-laptop-password.html
https://www.youtube.com/watch?v=zsjoYZjMvfc
https://www.freelaptopmanuals.com/toshiba_satellite_laptop_manuals.html
https://support.dynabook.com/repair
http://office.manualsonline.com/manuals/mfg/toshiba/toshiba_laptop_product_list.html
Toshiba... | Answered on Jun 19, 2020
no oS stated.
no THING stated, is it a MP4 movie ( nasty?) or what?
load VLC player, free , google it , from france. safe and free.
the load your video gpu driver next from toshiba.
no browser stated if downloading with one nor if all things fail downloaded, say a simple photo like JPG downloaded fails.
we can't guess what fails, not here.
Toshiba... | Answered on Jun 03, 2020
Flashing blue light means it is working!
solid blue light means it is not working!
no light means its not on!
Toshiba... | Answered on May 18, 2020
https://www.youtube.com/watch?v=5yRQejXvi9M
https://translate.google.com
¿C?mo hago para que mi computadora port?til Toshiba arranque desde USB?
Para arrancar esta unidad despu?s de muchas horas de intentarlo, lamentablemente solo por un error:
1.¡Reinicie su BIOS a la configuraci?n predeterminada!
2. Deje Secureboot activado.
3. Desactive Fastboot.
4. Guarde la configuraci?n con F10.
5. Mantenga presionado F12 mientras inicia para acceder al men? de inicio y seleccione su USB.
6. ¡Deber?a arrancar!
Toshiba C?mo: configurar la prioridad de arranque del sistema en BIOS
Toshiba... | Answered on May 12, 2020
https://www.youtube.com/watch?v=C9zrcx0PDhg
Toshiba... | Answered on May 07, 2020
The possibilities are too many for turning off itself.
1) It could be a heat issue with the TV set
2) It could be a software issue with the TV set, for example energy saving settings or active stand by mode.
3) It could be a timer set up in the TV set menu.
4) It could be a faulty power supply.
5) It could be a very unstable mains supply (not very likely, but possible)
You can check the user manual for information about +"TV power on control (Active Standby)"+
Sometimes the LED's on the front of the TV may indicate "the issue":
Just reset the network and try for WIFI issue:
To connect to a wireless network, perform the following:
  1. Press the "Setup" button on the remote.
  2. Use the up/down arrows to select "Network".
  3. Use the left/right arrow buttons to enter "Network Setup" and change the settings from "Wired" to "Wireless" if necessary.
  4. Select "Wireless Setup" and choose "Assisted Setup" from the available options and press the "OK" button on the remote.
  5. A list of available wireless networks will display, select the one you wish to connect to and press "OK".
  6. Select "Security Key" from available options and press "OK".
  7. Enter the network password for the wireless network you are connecting to.
  8. Once the correct password is entered, select "Done" and press "OK".
  9. Select "Done" again when prompted on the next screen and press "OK".
  10. The TV will connect to the network.
  11. Once connected, the screen will return to the "Network" menu.
  12. To perform a network connection test, go to the "Network Setup" menu and select "Network Connection Test" to verify the connection.
Toshiba HDNB120XKEG1 Canvio Personal Cloud Logo
4 questions posted
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
V Toshiba
  • V Toshiba
Most Popular Question
password reset
  • Computers & Internet
