20 Most Recent Precor C956i Treadmills with HR / WholeSale Questions & Answers
If you wish to get some details; check the site linked here. Pull up older posts for treadmills . Surf the site with patience. http://electro-medical.blogspot.com/
Precor C956i... • Answered on Aug 21, 2018
If you wish to get some details; check the site linked here. Pull up older posts treadmill . Surf the site with patience. http://electro-medical.blogspot.com/
Precor C956i... • Answered on Jan 10, 2016
Sometimes a bad MCB will cause a vibration at certain low speeds. If you have another unit, swap MCBs to verify. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Precor C956i... • Answered on Jan 18, 2015
If rebooting the treadmill does not fix that, it may have a problem with the Autostop feature. The MCB may need to be replaced to fix that problem. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display. 2. An interface chip (IC) has failed in the upper PCA's keypad. 3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display. Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor C956i... • Answered on Jan 14, 2015
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced. It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt. With your model and serial number, you can visit our website and view the products we have available for your particular machine. Precor Parts for 952i 954 954i 956 956i Treadmills SPORTSMITH net
Precor C956i... • Answered on Dec 08, 2014
This link will take you to the parts available for these models. Because most machines are serial number specific, you will need to narrow your search based on your particular model and serial number. Repair Parts for Precor C956 Treadmills 120VAC 240VAC SPORTSMITH net
Precor C956i... • Answered on Oct 31, 2014
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn. 2. Drive motor is shorted or de-magnetized causing a high power demand. Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Precor C956i... • Answered on Aug 11, 2014
Precor Error Code 42 Error Code: 42 Manufacturer: Precor Model: All Models Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits. If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Lift Position Value Out of Range Precor Error 42
Precor C956i... • Answered on Aug 07, 2014
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer). 2. Lift position sensor (potentiometer) is bad. 3. Lower PCA is bad. Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Precor C956i... • Answered on Jul 08, 2014
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Precor C956i... • Answered on May 12, 2014
The grinding noise could be asking for lube. If that is possible, do it.
Precor C956i... • Answered on Dec 13, 2013
see the video attached. God bless you
Precor C956i... • Answered on Oct 18, 2013
see this video and proceed according. God bless you
Precor C956i... • Answered on Mar 18, 2013
1) LUBE the DECK BELT inmediately, maybe you have a WORN deck replace if is necessary.2) LUBE the rollers bearings3) test the motor bearings and repair see the diagramGod bless you8_3_2012_12_08_54_am.gif
Precor C956i... • Answered on Aug 03, 2012
Precor C956i Treadmills with HR / WholeSale Logo
43 questions posted
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Relax
Relax
Aron
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Precor Exercise & Fitness
Most Popular Question
while running speed about 8 10 kph
  • Exercise & Fitness
