20 Most Recent Dmm Hudson EC-3500 Recumbent Exercise Bike Questions & Answers
Need a new pulse monitor for Cat eye ergociser
go to: www.fitnessgeneration.com.au they sell parts for the Cateye ergocisors.
regards
Erwin
12/23/2009 5:44:50 AM • Dmm Exercise &... • Answered on Dec 23, 2009
I need assembly instructions for wynne home gym.
Please check this link:https://www.google.com/search?sxsrf=ALeKk02D68ibDlpmqPFTdJFsPUAG8G7Hqg%3A1609823462652&source=hp&ei=5vTzX9vmJfG4mAXst4l4&q=assembly+instructions+for+wynne+home+gym&oq=assembly+instructions+for+wynne+home+gym&gs_lcp=ChFtb2JpbGUtZ3dzLXdpei1ocBADMgQIIxAnOgcIIxDqAhAnUIwSWIwSYPUXaAFwAHgAgAHwAYgB8AGSAQMyLTGYAQCgAQGwAQ8&sclient=mobile-gws-wiz-hp
4/5/2024 4:00:16 PM • Exercise &... • Answered on Apr 05, 2024
2answers
Where can I find a great treadmill deal on Black Friday 2023
The website TreadmillReviews.net has a black Friday page that you can see to find the best Black Friday deals https://www.treadmillreviews.net/sales/black-friday/. They have all the vendors and are featuring some of the best deals.
3/26/2024 8:02:23 AM • Exercise &... • Answered on Mar 26, 2024
What is the maintenance required for folding exercise bikes?
Cleaning: Regularly wipe down the frame, seat, pedals, and any other accessible surfaces with a damp cloth to remove sweat, dust, and debris. Avoid using harsh chemicals that may damage the bike's finish.
Lubrication: Apply lubricant to the moving parts such as the hinges, pedals, and resistance mechanism according to the manufacturer's recommendations. This helps prevent rust and ensures smooth operation.
Tightening: Periodically check and tighten all bolts, screws, and nuts to prevent loosening during use. Pay particular attention to the folding mechanism to ensure it remains secure.
Inspecting: Examine the bike for any signs of wear or damage, such as frayed cables, worn pedals, or loose components. Address any issues promptly to prevent further damage and ensure safety.
Storage: When not in use, fold the bike properly and store it in a clean, dry area away from moisture and direct sunlight. This helps prolong its lifespan and prevents corrosion.
Battery maintenance: If your folding exercise bike includes electronic components such as a display console, ensure that the batteries are replaced as needed to maintain proper functionality.
Regular servicing: Consider scheduling periodic maintenance checks with a professional technician to ensure all components are in good working condition and to address any potential issues before they escalate.
2/28/2024 9:12:11 AM • Exercise &... • Answered on Feb 28, 2024
Vitamaster 62C Exercise Bike. Maintenance - how to oil or grease where needed?
Question edited for clarity. Question moved from Food Mixers category. Same as a bicycle, so any parts that moves and has a pivot or a bearing. Help in the link https://www.google.com/search?q=Vitamaster+62C+oiling+or+greasing ..
2/22/2024 6:01:05 PM • Exercise &... • Answered on Feb 22, 2024
BodyTrain MT-196i Motorised Folding Bluetooth Treadmill. Brand new. Screen is working and programme can be set but motor will not start.
There is usually a breaker reset button near the motor. It is under maker warranty, so just contact them direct. https://www.google.com/search?q=BodyTrain+MT-196i+Motorised+Folding+Bluetooth+Treadmill ..
2/20/2024 6:27:09 PM • Exercise &... • Answered on Feb 20, 2024
Promaster pro plus 2 error code 31
Error 31 on your Promaster Pro Plus 2 treadmill could indicate a variety of issues, such as a problem with the motor or the motor controller. Here are a few troubleshooting steps you can try:
  1. Power cycle the treadmill: Turn off the treadmill and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again. Sometimes, simply resetting the treadmill can resolve error codes like Error 31.
  2. Check the motor connections: Make sure all the wires and connections to the treadmill motor are secure and properly connected. Loose connections could cause error codes to appear.
  3. Inspect the motor controller: The motor controller regulates the speed and operation of the treadmill motor. Check for any visible signs of damage or overheating on the motor controller. If you notice any issues, you may need to replace the motor controller.
  4. Contact customer support: If you're unable to resolve the issue on your own, it's best to contact the manufacturer's customer support for assistance. They can provide specific troubleshooting steps for your treadmill model and may be able to offer a solution or arrange for repairs if necessary.
By following these steps, you can hopefully resolve Error 31 on your Promaster Pro Plus 2 treadmill and get it working again.
2/20/2024 3:17:53 PM • Exercise &... • Answered on Feb 20, 2024
Treadclimber TC 200 treadles rubbing in the middle
Check Alignment: First, ensure that the treadles are properly aligned. Misalignment can cause rubbing. Make sure the treadles are parallel to each other and evenly spaced. Tighten any loose bolts or nuts that secure the treadles to the frame. Inspect the Walking Belt: Examine the walking belt for any signs of wear, fraying, or damage. A damaged belt can cause uneven movement and rubbing. If the belt is worn out, consider replacing it. Lubricate the Bolts and Joints: Apply lubricant (such as silicone spray) to the bolts and joints where the treadles connect to the frame. This can reduce friction and prevent rubbing. Be cautious not to over-lubricate, as excess lubricant can attract dust and debris. Check for Obstructions: Look for any foreign objects (dirt, debris, or small items) that might be caught between the treadles or near the alignment bolts. Remove any obstructions to ensure smooth movement. Inspect the Alignment Bolts: Make sure the alignment bolts are properly adjusted. They should be tightened enough to prevent excessive movement but not too tight to cause rubbing. Adjust the bolts if necessary.' Test the TreadClimber: After performing the above steps, test the TreadClimber to see if the rubbing issue persists. If the problem continues, consider contacting the manufacturer or a professional technician for further assistance.
2/15/2024 10:31:07 PM • Exercise &... • Answered on Feb 15, 2024
Dmm Hudson EC-3500 Recumbent Exercise Bike Logo
0 questions posted
Top Dmm Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Dmm Exercise & Fitness
Most Popular Question
lifespan treadmill tr2500 hr motor will
  • Exercise & Fitness
