20 Most Recent Ricoh Aficio SP C830DN - Printer - color - duplex - laser Questions & Answers
SC 544 is a fuser overheat error. This could be caused by power outage or fluctuation in the power.
go to service mode. Hold down both "home" and "simple screen" for about 5 sec. and then press "user tools"
once in service mode go to SP5810 reset fuser error.
and reboot the machine.
Ricoh Aficio SP... | Answered on Apr 08, 2017
does it have wireless capability? most ricoh/savin/lanier/gestetner machines must have an option installed.
if you have it networked via lan port and have a wireless access point on the same network you should be able to ping the unit and access the gui. if so it is already "wireless" in a sense
Ricoh Aficio SP... | Answered on Feb 07, 2016
Press the mode /clear (yellow)key press 107 press more than 4 seconds the stop/clear(red) key and in display SP mode.
Ricoh Aficio SP... | Answered on Feb 23, 2013
that is software program error. u need to update firmware
Ricoh Aficio... | Answered on Apr 16, 2020
I had the same problem, but solved it.
You have to connect your printer SP210 to your computer.
Search (in Windows) "Smart Organising Monitor Status"
Select Printer (new dialog box)
Click OK (see the error code SC545)
Click on User Tools
Printer Configuration
(Access Code is Admin074)
Find Fuser SC Reset under Maintanance
Click Ok
Close
Restart your printer
Your problem is solved now
OR
Without connecting your printer to Computer (you can do this):
Turn on the printer
Press C (Red colour centre) button once
Enter 107 (nothing will be shown)
Press the Green (Coping) button for 5 seconds
See the Display -->
Select Engine Maintenance
Select Ok
Select Fuse SC Reset (press down arrow - at down you will find it)
Execute (by Pressing the Down Arrow)
Done
Restart your printer.
Your problem should be solved....
Ricoh Aficio... | Answered on Aug 20, 2019
Check its connected to a network, the DHCP server is probably your router if you have a small or home network.
see
http://www.fixya.com/support/t25283562-solve_cannot_connect_dhcp_server_101#solution-section
Ricoh Aficio... | Answered on Jun 29, 2019
Probably, you will have to call your local Ricoh servicer for repair.
Ricoh Aficio... | Answered on Jun 27, 2019
SC 899 is a software error. For example printing from directly from a website. Various printing from websites makes 899 error. Just remove the print queue from the computer and that's it. Make sure you save the file first from the website before you print to avoid same problem.
Ricoh Aficio... | Answered on Jun 03, 2019
Replace Charge corona end blocks
Ricoh Aficio... | Answered on Apr 29, 2019
Ricoh Aficio SP C830DN - Printer - color - duplex - laser Logo
9 questions posted
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
help need getting rid sc 544 00 ricoh sp
  • Office Equipment & Supplies
