20 Most Recent
Lexmark CS410dn Color Laser Printer 28D0050 Questions & Answers
Why do I get red and blue dots when prnting pictures?
THIS machine has tendence to SPILL toner. Remove toner WASTE RECEPTACLE and GENTLY remove toners and DRUMS. check residuous acumulated over the transfer belt (do not touch or use chemicals on FUSER OR TRANSFER BELT .ALSO CHECK IF THERE IS TONER RESIDUOUS IN THE TRAY OR PAPER PATH. IF USING AIR CAN; COVER THE LASER UNIT (OF EACH COLOR) TO AVOID ACUMULATE IT AT THE LASER COMPARTMENT.
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
