20 Most Recent
Lenovo ThinkCentre M72E 4004-B8U Tiny Form Factor Desktop PC with Questions & Answers
How do i reset it my wireless adapter
If I were you, I'd first let Windows Manage Wireless Network Connections:
Click Start
If you're using XP, click Start then open the Control Panel. Find the Switch to Classic View button in the Control Panel and click it.
Open Network Connections
Open Network Connections then double-click the Wireless Network Connection icon.
Click the Properties
Click the Properties button. Look for the boxes at the bottom of the Properties window that read "Show icon in notification area when connected" and "Notify me when this connection has limited or no connectivity" and make sure they are both checked.
- You could also right click on the Wireless Network Connection icon and click Properties from there.
Open Wireless Networks tab
Open the Wireless Networks tab and make sure the box labeled "Use Windows to configure my wireless network settings" is checked. Then click OK.
- under Control Panel\Network and Internet\Network and Sharing Center you could find "manage wireless connection" there you could assign/delete wireless connection.
10/26/2014 11:23:50 AM •
Lenovo...
Answered
on Oct 26, 2014
Lenovo tiny
User manual here:http://support.lenovo.com/en_GR/downloads/detail.page?DocID=UM014622
11/29/2012 6:11:51 PM •
Lenovo...
Answered
on Nov 29, 2012
Install ram
Hithe ram is normally stored under the bottom of the laptop under a small cover.you have to remove the small cover and the ram is held in by two clips lift the ram up to unclip it from the frame.cheers
11/28/2012 1:14:15 PM •
Lenovo...
Answered
on Nov 28, 2012
Auto processing
The auto processing is the monitor trying to adjust to a particular resolution. To help you control display quality, please follow the steps given below:
-Open the 'Display Quality troubleshooter' by clicking the Start button, and then clicking 'Control Panel'.
-In the search box, type 'troubleshooter', and then click 'Troubleshooting'.
-In the left pane, click 'View all', and then click 'Display Quality'.
GuruAid.com
3/21/2016 7:05:57 AM •
Lenovo...
Answered
on Mar 21, 2016
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
4/5/2015 9:37:26 PM •
Lenovo...
Answered
on Apr 05, 2015
