20 Most Recent Emerson MW8987B/W Microwave Oven Questions & Answers
I can tell you what we did when we had that issue with our Maytag microwave. The door wouldn’t latch correctly and an appliance repairman said we would have to get a new microwave. My husband took the spring out and decided to just put the spring back. It had come unhooked somehow. He put it back and it’s worked fine going on 3 years later.
Emerson... | Answered on Feb 23, 2019
There are no user serviceable parts on microwave ovens, due to the danger of running one without the door in place. You will need to take it to a service centre. All of the screws are security screws that you need a special tool to remove.
Emerson... | Answered on Oct 27, 2015
Lamp replacement involves removal of the cabinet.
Emerson... | Answered on Mar 26, 2014
Usually this is due to loosened mounts inside the oven. The mounts hold the door switches and grab the door hooks when it the door is closed. The solution is to realign and tighten the mount screws inside. It's less liekly, but it could be a weak or worn door open lever inside. I only advise people to work on a microwave if they're fully informed and aware of the deadly hazards and necessary precautions.
Emerson... | Answered on Jan 06, 2014
it is behind the control panel but easy to get to if you remove the metal skin from the whole microwave (3 Screws)
Emerson... | Answered on Oct 11, 2013
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose or corroded connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron
- shorted high voltage diode
See the following help files on safety & disassembly and door switches.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Emerson... | Answered on Dec 01, 2012
The keypad control board is the likely problem, but the door switches should be checked first.
Emerson... | Answered on May 17, 2012
Unfortuneately the keypad control board must be replaced to resolve this issue. But keep in mind the part alone is more expensive than some microwave ovens.
Emerson... | Answered on Apr 27, 2012
Emerson MW8987B/W Microwave Oven Logo
72 questions posted
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Microwave Ovens
Most Popular Question
emerson mw8987w microwave won 39 t heat
  • Microwave Ovens
