20 Most Recent Apple iMac A1224 20" Core2Duo 2.66GHz 2GB 320GB MB324LL/A Questions & Answers
Mb324ll/a white screen
1.Try a Safe Boot Mac OS X 10.2 and later Safe Boot includes disk checking and repair. First start your Mac in Safe Mode. To do this, shut down your Mac. Now Turn on your computer by pressing the power key while holding down the Shift key. When you see the Apple logo, release the Shift key. After your Mac fully starts, restart your computer normally without holding any keys/buttons during startup. Note that Safe Boot is slower to boot. 2.Run Disk Utility Turn your Mac off by holding down the power button for a few seconds. Turn on your Mac and hold down the Command and R keys until you see the Apple logo. Then you should see a "Mac OS X Utilities" window. Select Disk Utility, click your OS X hard drive and select verify/repair disk. 3.Reset PRAM This may fix your boot failure. PRAM ("parameter random-access memory") stores some of your settings. You may reset PRAM. To do that, turn off your Mac. Now turn on your Mac. Then, immediately, hold down the Option-Command-P-R keys until your Mac restarts. When your Mac is starting up, release the keys. 4.Reinstall Mac OS X If nothing above works, you may try this. Your Mac needs to be connected to the Internet. See number#2 above. Follow the same steps. Restart your Mac and hold down the Command key and the R key until the Apple icon appears; when you see the Mac OS X utilities window, select the Reinstall option.
3/3/2015 6:14:38 PM • Apple iMac A1224... • Answered on Mar 03, 2015
Install new hard drive
I suggest checking out www.ifixit.com. You will need to identify your exact model and then you can find detailed instruction on the teardown , repair and re-assembly processes. I suggest READING it carefully BEFORE you attempt the repair. ALSO make sure you have all the CORRECT tools for the job. using tools not suitable will likely result in damage
4/29/2013 8:14:34 AM • Apple iMac A1224... • Answered on Apr 29, 2013
2answers
ERROR CODE 4M0T/4/40000003: HDD-1211
Install a new HDD. Press and hold Command, Option and R keys with a keyboard connected via USB. Power the mac on whilst holding down the keys. Release the keys when the globe shows and select your router code then download the OS for your mac. Install the OS. It takes some time to do this!
5/22/2022 12:09:27 PM • Apple iMac... • Answered on May 22, 2022
5answers
How to setup AirDrop on imac
You do not need to setup AirDrop as such. Just turn on the wifi and on the Finder sidebar go to AirDrop.
9/27/2021 8:36:46 AM • Apple iMac... • Answered on Sep 27, 2021
3answers
How can i download my picture from desktop to my i phone
Send it as an email to yourself
6/21/2021 6:35:26 AM • Apple iMac... • Answered on Jun 21, 2021
2answers
4sns 1 4000000 th00 9.000
There are several causes for this:
  • Dust buildup in the computer prevents proper cooling, so the fans have to work harder.
  • Corrupted Power Manager chip settings. Go to the Apple support page and search for "Power Manager" "reset" and your specific model. You can get the model number from the System Profiler utility (Apple menu: About this Mac: More Info). If this is the problem, resetting the Power Manager should solve it. If it happens again after unplugging, you may need a new clock/PRAM battery;
  • Bad temperature sensor (all fans run at high speed);
  • Shorted fan driver transistor on the logic board or in power supply (one fan always runs at max speed).
3/6/2021 5:01:04 AM • Apple iMac... • Answered on Mar 06, 2021
HOW TO CHANGE A CLOCK BATTERY ON AN IMAC 2013 27" DESKTOP ALL-IN-ONE
1. in imac u first pull out the display 2. then remove the motherboard in the backside of the motherboard u see cmos battery remove the battery , replace new one
9/4/2019 9:43:51 AM • Apple iMac... • Answered on Sep 04, 2019
Help yahoo com
Hi, If you are sent bulk mail then you are not used public email server. Because public email sent normal 10-50 max email one day. If you are bulk mail sent then you are purchase extra space or server. If you are want yahoo through sent email then contact yahoo and ask i want to sent bulk mail so yahoo available space or service and also yahoo charge taken. Thanks, MacHealthCheck
1/25/2019 3:30:42 PM • Apple iMac... • Answered on Jan 25, 2019
Imac pc unable to change the @ on a uk keyboard
Please select a different keyboard layout Click the Apple icon from your menu bar, select System Preferences, and then follow these steps. 1) Click Keyboard. 2) Make sure you're on the Input Sources tab. 3) Click the plus sign button on the bottom left. In the pop-up window, you'll see a list of languages on the left and options for them on the right. You'll also see a preview of the keyboard layout.Select the language you want and then pick the option on the right. For example, French > ABC - AZERTY or English > Dvorak. 5) Click Add.
1/17/2019 9:14:49 AM • Apple iMac... • Answered on Jan 17, 2019
I need delete my Guest account on my MacBook Air
Hello, For removing the guest account Click on Apple menu on the desktop and select system preferences then click the user & Users icon in the system action. Click the bottom right corner and then enter you account and password as prompted. This unlock the setting allow to make a changes.
1/2/2019 11:14:23 AM • Apple iMac... • Answered on Jan 02, 2019
2answers
How toEject a stuck CD in Imac?
If your Imac is in Warranty period than don't go for these process. Call your near by Apple support any demand for service http://www.apple.com/imac/ . but if you are out of warranty than Try to Eject it from Desktop Disk Drive or Restart your Imac and try to eject. if still not help than follow Mac Support .
11/26/2018 8:43:55 AM • Apple iMac... • Answered on Nov 26, 2018
IMac rejects CDs or won't recognize CDs
hi, posible theres a problem on ODD lense, you try to clean the lense or replace new odd thank you
10/4/2018 2:24:33 AM • Apple iMac... • Answered on Oct 04, 2018
2answers
How do i send email with a large attachment from my imac
Hi Attachments to email should be less than 10mb. Your ISP sets the limit. Open an email and get it ready to go. Put cursor where you want the attachment to sit on the page. Drag your file to be attached, from the Desktop to the Email window & drop. Then clik send. For larger attachments: Use the free DropBox to share files with friends. You place files to be shared in the Dropbox Folder which shows in the top menu of a Mac. Very simple to use, once set up. https://db.tt/7ByRbUj Cheers Trevor
9/20/2018 10:31:17 AM • Apple iMac... • Answered on Sep 20, 2018
Presentation on Mac
To know how to repair powerpoint file - this is Google. But in it there is PowerPoint online service it works under Windows, Android, Mac with any types of files. Just try it on How to recover data from damaged PowerPoint presentation
6/7/2018 9:14:43 AM • Apple iMac... • Answered on Jun 07, 2018
Data on Macintosh is under the threat
I would offer you some variants, what to choose - this is your preference... As we know Google is our friend - how to repair damaged pdf file - this query might be too Nowadays day-by-day Macintosh Online Service becomes more popular, it was found https://onlinefile.repair/en/pdf.html on search machine
3/30/2018 4:55:55 PM • Apple iMac... • Answered on Mar 30, 2018
2answers
How do I turn off male voice that announces everything I type and do on the computer?
command and f5 should turn it off. or go into preferences and accessibility to turn it off
1/23/2018 3:06:33 AM • Apple iMac... • Answered on Jan 23, 2018
3answers
How to unlock a grey out hard drive on mac with maverick
Some mac user solve this problem by 1. Boot up from your OS X Install Disk / USB Stick and Launch Terminal and type "diskutil partitionDisk disk0 jhfs+ MacintoshHD R". if need any technical guidance over follow http://store.apple.com/us/help/contact and Apple and Mac Technical Support on Mac OS X .
12/29/2017 3:15:28 AM • Apple iMac... • Answered on Dec 29, 2017
Apple iMac A1224 20" Core2Duo 2.66GHz 2GB 320GB MB324LL/A Logo
2 questions posted
Popular Products
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iMac Apple
  • iMac Apple
Most Popular Question
mb324ll white screen
  • Computers & Internet
