20 Most Recent Sony VAIO VGN-NR310E/S Laptop Questions & Answers
Yep ~ welcome to the SONY BLUES.
You see SONY has a nasty habit of using up to 5 and more DIFFERENT WiFi BOARDS and they are NOT alike... each requires a SPECIAL Driver unique just to it!
So a SPECIFIC MODEL SONY 123XYX LAPTOP (example) CAN and DOES have many DIFFERENT WiFi cards in it. Only ONE card, but potentially different manufactures!
I don't intend to be redundant, I just need you to fully understand your problem! And sadly it's not JUST the WiFi cards! It may be Audio or even USB Drivers! BOOO SONY!
What's more is SONY does NOT have the courtesy to put all of those drivers on one CD ~ the rats.
I again recommend a FREE download of SPECCY. It SHOULD tell you ALL you need to know about your WiFi and almost ALL other hardware in your System(s)! Heck it even tells you your CPU temperature! See the links below...
Armed with the SPECIFICS, hunt for the FRESHEST drivers you can find for your specific card AND be SURE to MATCH your Operating System too! Is it Windows 7 32-Bit or 64-Bit?
Anthony
https://www.piriform.com/speccy/download/standard
HERE IS A SPECCY TUTORIAL:
Speccy Tutorial for Beginners
Sony VAIO... | Answered on Dec 02, 2017
Is it VGN-NR310E/S?
if so go to:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNNR310ES&LOC=3
All the drivers for XP as well as Vista Home Premium are there.
Hope this helps.
Bastian
Sony VAIO... | Answered on Aug 22, 2015
with out the sound driver you wont have sound
Sony VAIO... | Answered on Apr 01, 2015
it sound like the video s starting to fail. get a new at a pc store or buy buy and they are easy to replace.
Sony VAIO... | Answered on Feb 28, 2015
Generally, the reset is a tiny hole with a circle around it on the bottom of the unit. Most are marked with the letters "RST". The hole so small you will need a paperclip or something similar to insert into it.
Sony VAIO... | Answered on Jul 27, 2014
first goto bios menu
change boot option
then boot from cd
done
Sony VAIO... | Answered on Dec 05, 2013
Probably a new battery if yours is old.
Sony VAIO... | Answered on Nov 25, 2013
That would be desktop resolution.
Right click on desktop. Select Screen Resolution or go to Control Panel\Appearance and Personalization\Display\Screen Resolution
Sony VAIO... | Answered on Oct 09, 2012
To view? IE has a zoom and a text size under page drop down.
Depends on the web browser. For instance I use Chrome. There is zoom option. Wow, I can take my glasses off (I'm testing right now).
To make?
HTML code for web pages.
<h1>Text<h1> Largest
<h2>Text<h2>
<h3>Text<h3>
<h4>Text<h4>
<h5>Text<h5>
<h6>Text<h6> Smallest
Note that the microphone is not listed individually in Device Manager because it works through your sound card. Perform the steps in the following sections in order, and then test to determine if your issue is resolved after each section.
NOTE: The microphone should be selected as the recording device in the Volume Control tool(sndvol32.exe).
To verify this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type sndvol32.exe, and then click OK.
  3. Click Properties on the Options menu.
  4. In the Adjust volume for box, click Recording.
  5. Click OK.
  6. In the Microphone box, verify that the Select check box is selected.
All the properties listed on the Playback section of the Volume control are independet of the recording settings. So you could record through the microphone by selecting it on the recording section, and mute it on the playback section. Then, you could record sound, but wouldn't hear it through the speakers while you are recording.
Check Your Hardware loadTOCNode(2, 'moreinformation'); If your microphone has never worked, or if it has stopped working, first check the physical connection of the microphone. Verify that it is firmly plugged into the microphone port instead of the headphone or speaker port. If you are not sure which port is correct, you can check the sound card to see if it is marked (sometimes with a picture of a microphone), you can use a process of elimination, check the documentation that came with your hardware, or contact the hardware manufacturer.
Sony VAIO... | Answered on Jul 24, 2011
use niro or ashampoo
Sony VAIO... | Answered on Jun 17, 2011
trt to press and hold FN + F1 or with button wich have antena symbol
Sony VAIO... | Answered on Apr 30, 2011
It could be a Operating system issue, or a hardware voltage issue.
I would place my bets on the OS. Simple solution is to update your driver, if that does not work, reinstall your OS
Sony VAIO... | Answered on Feb 24, 2011
SCAN FOR HARDWARE CHANGES IN DEVICE MANAGER UNDER ACTIONS AT THE TOP THEN REBOOT WHEN CHECKED SEE IF THAT HELPS IF NOT CHECK ALL UR UR UDATES HAVE BEEN INSTALLED
Sony VAIO... | Answered on Jan 08, 2011
Go to Sony.com and input your model number where requested. There should be a list of available up to date drivers for download.
Hope that helps.
Sony VAIO... | Answered on Nov 14, 2010
Hi aramsfn,
The Recovery Discs for the Computer is available for purchase at Sony Accessories and Parts Center. You can place an order online to purchase the Recovery Discs for the Computer. Below is the link to view the Details of the Recovery Discs and place an order to purchase it.
Please copy and paste the link in a new Internet Explorer window and press the Enter Key to open the page.
https://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=665036&searchOperation=modelSearch&searchText=VGNNR310E/S
Hope this helps.
Good Luck!
Please post back if you require further assistance.
Thanks for using FixYa.
Sony VAIO... | Answered on Oct 30, 2010
Dear,
Plz help me.
My crdit card in lock for six month complit.
My name.satish sakharam choudhari.
Mob.no.9270377030
Card no.4181 5702 0303 5915.
Card valid dt. From 02/09 .
Valid thru dt.01/19
Best Regards
Satish Choudhary
Sony VAIO... | Answered on Oct 07, 2010
Try removing the drive from the device manager and rebooting the pc.
Have you got burning software installed already?
Sony VAIO... | Answered on Aug 14, 2010
Sony VAIO VGN-NR310E/S Laptop Logo
38 questions posted
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
head phone jack not working
  • Computers & Internet
