20 Most Recent
Toymax Frisby 2 GB Wireless Sport Mp3 Player Headset MP3 Player Questions & Answers
How to charge a cativa AT-MP420 portable Media Player
Ti charge the MP3 player, connect the supplied USB cable to the player and then plug the other end of the USB cable into the USB port of your computer.ORPurchase a 5 volt mains USB power adapter and plug the USB cable from your player into the USB port on the power adapter.
What all do i need
should only need a USB cable, a computer with a USB port, and music files.
Check "My Computer" when the media player is plugged into the computer and powered on. It should appear as an external storage device. Then just copy you music files onto the player.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
I have a Fisher 5
The E display indicates disc loading error.Due to inactivity the carousel loading trays rubber belt would have either become stiff or loose ( depending on which part of the world you live in ).So your loading action is not being completed due to your loose loading belt condition.
There are sensors ( small leaf switches ) which tell the micro controller if the tray has gone in completely and lifted the CD off the carousel tray, only after that the CD starts spinning for play operation. If this sequence does not complete the tray opens and closes by itself in some makes and model during power On
If you are up to it you can open the top cover and see the loading tray and beneath it is the loading belt.Your challenge is getting a replacement today of an old model.
