20 Most Recent Asko W6222 Top Load Washer Questions & Answers
that is basically what it does
stops coins buttons bra wires etc
most washing machines have a section in the pipe before the pump where the hose comes out a few inches above the bottom and this is like a trap where objects fall and are retained
as most machines are difficult to get to the hose or pump , having a filter there is a bit impracticable as you would be cleaning it every other wash
if your machnie doesn't have an end trap arrangement you could improvise such a unit using a "T" section of plastic pipe with the hose on one end , a cap on the other and the hose to the pump from the middle
Asko W6222 Top... | Answered on Feb 28, 2018
hi you need to remove the plastic ball and ring from the sump hose under the drum,also dont use anymore than 2 tablespoons of soap
Asko W6222 Top... | Answered on Aug 20, 2015
PLUGGED HOSES OR BAD WATER PUMP
Asko W6222 Top... | Answered on Apr 03, 2015
The way the pump was installed must be not right or the new pump is defective.
Asko W6222 Top... | Answered on Jan 17, 2014
Sounds like the inlet water valve is not seated properly and is letting water in when it shouldn't .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Asko W6222 Top... | Answered on Jun 20, 2012
F3 error code means your washer has not drained. To fix the washing machine error code is simple and straight forward. Simply remove the drain pump filter and slide the filter out and clean the debris inside. The filter in most cases is on the lower bottom panel. Simple depress the tab and fold the access door down. The washer drain pump filter is a white handle twist the handle to remove the filter. You may also find an article of clothing trapped down where the filter is like socks or change etc. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
Asko W6222 Top... | Answered on Oct 01, 2011
No theres not, Only at the water inlet.
Asko W6222 Top... | Answered on May 13, 2011
If F3 is flashing, then you are having a problem with drainage.
Check that there is no object stuck in the drain hose outlet. Check that the pump is not blocked by foreign objects and clean the pump. Check that there are no kinks in the drain hose.
After making these corrections, run the drain program or press the key button (door open) to empty the machine.
Asko W6222 Top... | Answered on Feb 10, 2011
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings.
Asko W6222 Top... | Answered on Jan 28, 2011
clean filter ...bottom right.front.
Asko W6222 Top... | Answered on Jan 23, 2011
if the valve was stuck open it would run all the time the washer was on i would say that there is a power short running to the valve turning it on when not selected
sonic boom electronics australia
Asko W6222 Top... | Answered on Jan 04, 2011
Asko W6222 Top Load Washer Logo
43 questions posted
Top Asko Washing Machines Experts
Michael Thomas
Michael Thomas
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Asko Washing Machines
Most Popular Question
w6222 filter gauze mesh or some
  • Washing Machines
