20 Most Recent General Electric WJRR4170GWW Top Load Washer Questions & Answers
My washer GE model #
Make sure the pin in or on the Agitator is not broken or sheared
9/1/2018 4:17:56 AM • General Electric... • Answered on Sep 01, 2018
Wont spin
Sounds as though the motor brushes have gone, replace the motor brushes this should rectify the problem straight away... I hope this helps....
9/1/2018 4:09:15 AM • General Electric... • Answered on Sep 01, 2018
Washer tub/basket is visibly uneven or unbalanced
Check the rubber damper straps ('cables") by hand to make sure they aren't cracked or broken (a light tug on each should suffice). Sometimes it isn't obvious visually, especially if you don't have good lighting. If one strap is bad, replace the entire set. Also inspect the attachment points for the straps to make sure they aren't loose or bent. If you are sure the damper straps are good, then check the suspension under the tub for excess wear or breakage.
7/25/2017 7:09:03 AM • General Electric... • Answered on Jul 25, 2017
Sounds like its spinning but dont
check in bottom of your washer for cuted belt which is rotating from motor to drum
5/10/2014 10:10:19 PM • General Electric... • Answered on May 10, 2014
0answers
Dripping water into tub when not in use.
Sounds like one of the solenoid valves is leaking. These are the parts that the hoses connect to on the washer, they are essentially like electrically operated taps. To replace, simply remove the hoses, undo the wiring to the valve, remove the valve and replace with a new one.
7/23/2011 1:12:05 AM • General Electric... • Answered on Jul 23, 2011
It seems like our washing
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
6/27/2011 4:23:28 AM • General Electric... • Answered on Jun 27, 2011
I have a piece of clothing under the tub. How can
if it's just a piece like a shirt or pants live without it!!! Just kidding sorry but you should be able to pop a panel off the back after removing some screws and pull it out. (Please unplug the washer first) shouldn't be to exstensive off a job
2/10/2011 6:25:44 PM • General Electric... • Answered on Feb 10, 2011
LOUD NOISE ON SPIN CYCLE
its got to be the bearing u can go to this web site to get a sevice manual to help u in this matter
12/1/2010 5:42:42 PM • General Electric... • Answered on Dec 01, 2010
My washing machine will not go through the spin
he lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.Replace with this part. Here is a video to show you how to replace the switch.
12/1/2010 12:05:24 AM • General Electric... • Answered on Dec 01, 2010
Brand new GE washer only 2 yrs. old stops
Probably a bad timer/module control assembly. It works for a short time then the metal contacts get hot and "open up". The timer control mod is what's behind the big knob. About $90.00.
11/1/2010 2:55:28 AM • General Electric... • Answered on Nov 01, 2010
Agitator not moving, how do I get it open to check
My machine is not agitating, I already have had one repair before it was a year old they replaced the agitator, any suggestions how I can get it going again with out a major repair cost?? ugh!
10/16/2010 9:43:09 PM • General Electric... • Answered on Oct 16, 2010
I need a diagram of the assemble?
Go to appliancepartspros.com put in brand and model. this will pull up complete schematics and parts for machine.
8/25/2010 7:57:17 PM • General Electric... • Answered on Aug 25, 2010
Ge wjrr4170gww will agitate empty but not with
Agitator coupling is usually the problem. Remove agitator (just pull it up hard) and replace the part under it, it costs just a few bucks, part number WH43X10032, Repairclinic.com should have pictures of the part if you enter the part number in the search box.
Vlad
First Choice Appliance
8/21/2010 12:35:51 AM • General Electric... • Answered on Aug 21, 2010
Will not pump out - is this a cloged filter?
Either that or the Pump, most common, the outlet Hose, then filter.
3/15/2010 10:02:20 PM • General Electric... • Answered on Mar 15, 2010
General Electric WJRR4170GWW Top Load Washer Logo
61 questions posted
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • General Electric Washing Machines
Most Popular Question
dripping water into tub when not in use
  • Washing Machines
