20 Most Recent Maytag Centennial MTW5800TW Top Load Washer Questions & Answers
Could be excess fabric softener or a dispenser problem. The dispenser is supposed to get flushed as part of each wash cycle. Maybe the flushing is not happening.
Maytag... | Answered on Feb 21, 2018
Sounds like the lid lock itself is bad, be sure to check the connections at the control board. There should be a tech sheet inside the front panel towards the top left. This can help you check the error codes and wiring diagrams.
Maytag... | Answered on Dec 04, 2017
this is a design 2000 mfg by whirlpool. great design and been around for some while. "If" it drains but doesn't spin or agitate, it is the transmission drive coupler. part no 285753a. very common problem. it is the sacrificial part between the transmission and motor. Amazon com 285753A FACTORY OEM GENUINE WHIRLPOOL KENMORE DIRECT DRIVE...
Maytag... | Answered on Jun 13, 2017
press cancel twice and unplug. If that doesn't work then the lock maybe faulty.
Maytag... | Answered on Apr 03, 2016
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Maytag... | Answered on Mar 24, 2015
Check the drain where ti empties into, smell the drain thats most likely where the odour is coming from.
Maytag... | Answered on Feb 04, 2015
Sensors are usually engaged by a depression of a tab.located directly under the cover. Replace the tab in the cabinet or use something to ensure it is pressed down.
Maytag... | Answered on Jun 15, 2014
Maytag Centennial MTW5800TW Top Load Washer Logo
198 questions posted
Top Maytag Washing Machines Experts
John Tripp
John Tripp
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
begins fill wash stops starts low
  • Washing Machines
