20 Most Recent
General Electric WJRE5500GWW Front Load Washer Questions & Answers
How do you open the top of ge washer model WJRE5500G2WW
You may need to put a level on top of the washer and then there are little feet like under the washer you will need to turn those either way untill all 4 are right, meaning once the level says it is level then you are ok and avoid overloading.
My washer is leaking from the bottom
It would, as water runs down due to gravity. Does it leak only during a certain cycle (like spin)? Is the washer under warranty? Could be as simple as a seal needing replacement, but you may have to either get a repair man or get a new washer.
Basket not spinning
Check the door switch to make sure that it is ok. The motor in this is direct drive so it could be the controller.
Washer continues to fill but
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
On the spin cycle my washer is banging very
Sorry to read about your problem, I hope this helps you out.
you may lost or have weak balance springs/rods in you machine, It does take experience to work with and balance machines.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
I have successfully opened the
Most agitation have screws on it, to remove the agitator, please follow the steps below:
1. Unplug the GE washer from the wall outlet. Open the washer lid to access the agitator.
2. Grab the bottom of the agitator with both hands and pull the agitator
out of the washing machine. If the agitator will not budge, rent
agitator hooks to pry the agitator out. Agitator hooks are available at
appliance repair stores. Set the agitator hooks under the agitator and
push down on the handle to pull the agitator off the shaft.
3. Pry off the plug on the top of the drive bell on the agitator shaft
with a small flathead screwdriver. Use a socket wrench to remove the
hex head bolt at the top of the drive bell. Carefully pull the drive
bell up off of the agitator shaft. This may take some force depending
on how stripped the inside of the drive bell has become.
4. Then you can now remove the agitator once the belt is out.
Good luck and have a good evening!
MY WASHER WILL FILL, SOAK
Hi
Thanks for using FixYa. If your washer pumps out the water
but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine
doesn't spin. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the washing
machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted
to the shaft of the motor on one side, and to the transmission on the other.
Over time, the coupler wears out and fails. You may need to replace it. A belt
may be broken. Many washing machines have one or two belts. If a belt is broken
or badly worn, you need to replace it with a genuine belt from the
manufacturer. (Some washing machine belts are designed with special
characteristics not found in automotive belts.) The clutch may be worn. It may
use a clutch to come up to the proper spin speed. As the clutch wears out, it
may prevent the unit from spinning well or at all. If the clutch is worn, you
need to replace it. For this job, you probably want to hire a qualified
appliance repair technician.
The drive motor may be defective. Many washer brands use a
reversing motor. For agitation the motor runs in one direction, for spinning
and draining, the other. It's possible for a motor to burn out in one direction
and continue to operate in the other. If this happens, you need to replace the
entire motor.
The spin bearing or basket drive may be worn or seized. These
components allow the inner tub to spin freely inside the outer tub. The
transmission may not be shifting properly. If the shifter becomes even
partially defective, the unit may drain the water but not spin. This is a
complex system, if your washer has a shifter problem, you may want to hire a
qualified appliance repair technician to repair it.
Please do accept the solution if the issue is
resolved or else revert for further assistance.
Thanks
Rylee
While it is agitating there is a loud clunking
I had the same problem and fixed it today. all you have to do is take a putty knife and on the front of the washer, just under the top there are two clips that hold the front on. the top doesnt need to come off at all. the clunking sound means that at some point the washer was perhaps overloaded and is now bottoming out when it gets to a certain point in the agitation. take a pair of pliers and rebend the silver mounts in the front corners where the tub is suspended
Clicking noise during wash and rinse cycle
The transmission has gone bad. I hope this machine is still under warranty. I own my own applaince service company where we do warranty work for GE. This problem is well know by GE. When we receive a warranty service call for one of the GE top loaders and we diagnose the unit with this problem. GE will only pay us the trip charge and diagnosis fee. They replace the machine rather than repair them. The GE dealer that delivers the new unit is not allowed to leave the used unit but to take it with them and later destroy it so that no parts are useable. GE has had a real bad problem with their transmissions in their top loaders for about 10 years or so. You will find that it is cheaper to buy a new machine rather than replace the transmission even if you were to do it yourself. If the unit is not been out of warranty for very long, I suggest you call GE, give them your model# and serial #. tell them it has a bad transmission. Let them know that you understand that they are totally aware of the problem with their transmissions in top loaders. That you expect them to either grant you large a discount on a new machine or to cover a high % of the cost of repairs to the one you have. I understand that they have done both for customer in an attempt to avoid class action judgments. It' s worth a try. Sorry for the bad news but I see this all the time.
P.S. GE is still building bad equipment. They are surviving on their name because thay have totally destroyed their reputation throughout the industry.
Please rate solution.
General Electric portable washing machine.
Question edited for clarity.
Better known as 'space saving' washing machines, they are a compromise at best.
Try presoaking the clothes overnight. Do longer programs. Try changing detergents. Wash twice.
General electric Washer gtup270em0ww
Pumping out or leaking out?
There are various rubber connectors underneath and they can perish and leak. There is a trick. slide a piece of paper under it. Switch on and after a minute, pull the paper out. It will give you a rough idea where the leak is, front, back, left or right. Then pull the machine out, and tilt it safely against the wall, get someone to hold it and look with a flashlight for the area where the wet patch on the paper was.
Parts
https://www.google.com/search?q=ge+gtup270em1ww+parts
