20 Most Recent
Navigon MY GUIDE SAT NAV 3100 SERIES Car GPS Receiver Questions & Answers
Haveing trouble selecting first and second gears when engine cold
hope you not using sat nave to try and select a gear you will have trouble..... any way check that you have oil in the gear box and dont have a leak. if you have a leak then you dont have enough oil in the box. if all fine and no leaks check the level of oil and add some if low. also grease up the gear changer shaft at both ends. check for rubber seal damage. if all ok just grease them. wile you under the car have some one move the gear stick from first to second with out the engine moving checking that the alignment of the gear change shaft . making sure the shaft lok dose not move with the a gap. if so check it or change the part.
My nokia c1 is asking to entur puk code pin code
HelloThank you for using Fixya!!The PUK code requested is an unique code to each phone. At
the link below you will be directed to a tip i wrote on how to recover
your PUK code.Click HERE to navigate.Kind regardsLock123
Please insert the memory card. I have a brand new
Best thing you can do, get a card reader, hook that up into your computer, check the sd card and make sure that it is blank. Then copy the the original sd card to the new sd card, put the original card away in a safe place and keep it for when you need to reinstall a new sd card. Of course if you don't want to do that then just stick the original sd card into the side of the gps unit and use it till it starts to act up. At which point you will need yet another original sd card from the manufacturer. It's a viscous cycle. Hope this helps
Screen keeps turning off
Some sat-navs have this feature as a power saving option, try looking through the menu to see if there is something like turn screen off
My Guide 3100, Will not switch on when connected
Problem solved.
Electrician friend came round, told him of problem,all he did was to turn
it over and usinig a small screwdriver pushed the reset button and it fired up alright.was told by retailer that reset would only set unit back to
factory settings.
