20 Most Recent Tomtom GO 520 GPS Receiver Questions & Answers
Reset it. If that doesn't work, you need to have it repaired or replaced. If you have had it longer then 5 years, it is past its best by date. Having said that, you say it works fine to start with, so it can't be much wrong. If the sound comes via Bluetooth, delete the entry, reboot all devices and re-pair them.
Tomtom GO 520... | Answered on Sep 16, 2017
I had the same problem. Ended up using another computer
Tomtom GO 520... | Answered on Jul 05, 2017
Contact TomTom support (on-line ) for assistance ... at:
https://us.support.tomtom.com/app/contact
Tomtom GO 520... | Answered on May 02, 2016
The map you have loaded in you TomTom Go 520 was not indented to be used with this device or you have not acquired the right to use it with the device. Check with the place whence you got it.
Tomtom GO 520... | Answered on Dec 05, 2013
my tomtom is locked, i can not rember my tomtom coad,how i remove the coad
Tomtom GO 520... | Answered on Sep 13, 2011
Possibly from leaving the gps charging too long the battery may not be able to hold a charge. Best suggestion would be to always use with car charger when you travel with it.
Tomtom GO 520... | Answered on Mar 04, 2011
The difference in capacity between 1320mAh and 1300mAh is minor (we are talking about a 1,6% difference, this is below production variance anyway). If the voltage and battery type is the same and the new battery fits inside your device, there will be no problem.
Note, the 1300mAh is the capacity of the battery (how much energy it can store). The main information this value gives is how long a device can work without the battery needing a recharge. You need to be concerned only about the output voltage of the battery (measured in Volts, abbreviated V, and the chemistry type of battery like NiMH, LiIon, LiPo, NiCd). The voltage should match the original so that your GPS device works properly without getting fried or underpowered; the chemistry type must match so the battery and the charging electronics do not get damaged when the external charger is connected.
Tomtom GO 520... | Answered on Jan 04, 2011
Normally the voice commands are only available in the "Computer generated voice" mode. If you select any other voice, the feature is disabled. Hope this helps
Tomtom GO 520... | Answered on Oct 06, 2010
Built-in FM Transmitter to transmit sound over own car stereo and lets not forget Best hands-free calling> Best guess is that your computer is finding and trying to connect to the blue tooth connection since Toshiba has blue tooth capabilities, also you could be losing the wifi signal just because the FM transmitter is overpowering the the wifi signal. If i had to guess though i would go for the blue tooth connection as being the problem. Hope this helps
Tomtom GO 520... | Answered on Apr 27, 2010
I had the same problem until my wife quickly figured it out.Touch the main part of the screen and then touch change preferences.Hit the forward arrow several times {4 on mine}then you will see "set clock".I'm not sure if i have a 520 ,but it is a tom-tom.
Tomtom GO 520... | Answered on Mar 09, 2010
GPS devices often won't start at all if the battery is too low and need a full charge before you can see anything happen. Try it again once making sure you have leads that can charge it.
Tomtom GO 520... | Answered on Feb 20, 2010
go to tomtom.com, go to support, search for reset, select your device do as told. includes fotos of resetbutton and good discription. first make sure battery is full. goodluck.
Tomtom GO 520... | Answered on Feb 12, 2010
Computer has malfunctioned and windows XPdoes not recognize it-
Tomtom GO 520... | Answered on Jan 17, 2010
check address referencing and navigation search settings with out error
Tomtom GO 520... | Answered on Dec 16, 2009
It sounds like your mini usb connector is damaged. If you're handy you can buy a replacement and solder it in. You will need a very fine tip soldering iron and a magnifying glass. The repair can be quite challenging as the components are surface mounted.
Otherwise I can fix it for you for a small fee.
I've repaired about 20 tomtom units with similar problems. I charge around £35 for this including return postage
Tomtom GO 520... | Answered on Dec 05, 2009
"Can I preserve my Favorites when upgrading?":
Yes, when you make them PIO's (Point of Interest). The procedure is
described on the TomTom website:
http://uk.support.tomtom.com/cgi-bin...p?p_faqid=7028
If you want to know why POI's are preferred over Favorites:
http://uk.support.tomtom.com/cgi-bin...p?p_faqid=6871
Tomtom GO 520 GPS Receiver Logo
55 questions posted
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
View Most Popular
GO Tomtom
  • GO Tomtom
Most Popular Question
tom tom 520
  • GPS
