20 Most Recent
Garmin n?vi 765T Car GPS Receiver Questions & Answers
I left my Garmin 765t GPS in the car over a very
While the rechargeable lithium-ion batteries inside the GPS can operate in a fairly wide temperature range, leaving the battery out in anything less than -10 weather will render the battery inoperable. Unfortunately your battery has probably been exposed to a lower temperature, and therefore will no longer take a charge. You will have to replace the battery. Depending on the retail source that you bought it from you should be able to purchase a replacement unit from them. On a side note, lithium batteries normally have a 3 year lifespan, and you would have to replace after that time-frame.
Thank you for the opportunity to assist you in resolving your issue.
Should you need further information or assistance please do not hesitate
to let us know.
I have a garmen Nuvi 720, it charges on computer,
Hi, this may be result of errors in both hardware concept and respective operation system software. if you have any warranty time, then try to hand over that in order to collect new one. have fine as early
I have found a 765 garmin and i dont know the pin
Nope you cant reset the unit.....
All Garmins are registered with Garmin for the reason of if ever lost the unit would have to be unlocked by the rightful owner... the Serial number is located on the bottom of unit in the middle
Beware if the unit was ever turned on remember its a GPS they can find you quicker than you finding them
Be that nice guy and give Garmin a call and they can tell by the serial number who the owner is....
Thanks for being Honest
Its an expensive unit with good security
New garmin - got latest updates from garmin loaded
Garmin only allows you one free update for your GPS as long as you download and install it within 60 days after you purchase your unit. If you have tried to download any updates after your 1 free update without paying the update fee you would get the error you have mentioned. If this is your first update, or you have paid for it, and you are getting the error, the map has become corrupted. You'll have to contact Garmin's support and they will have to supply you with a code to use to unlock the map.
What is the pin to unlock my garmin nuvi 750t
Do this by pressing and holding the bottom right corner of the screen
while powering up the unit. Hold the corner of the screen until the
message window "Do you really want to erase all user data?" pops up and
proceed with your choice.
Then reenter info
Garmin nuvi 765t won't power up
This is likely a failed battery.
The battery on these units is not user-replaceable (soldered to the PCB) and must be returned to Garmin for repair.
CLICK HERE to see more about their FLAT RATE repair service.
Your 765T is listed as a $99 flat rate repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
How to charge garmin 765 on computer
Very simple: connect the cable that came with the GPS: USB end to computer, mini USB to the GPS. When the unit is charging, the battery icon will disappear.
Unfortunately, Garmin did not think you would want to know the percentage of charge completed (they confirmed it to me in email), so you have to guess that after 2-4 hours your GPS is fully charged.
How can i remove tunes from a garmin 765t mp3
Connect the GPS to a computer via supplied USB cable and:
- The GPS will be recognized as a new drive. If a pop-up appears choose "Open Folder To View Files." If not, click the "Start" button, then go to "My Computer." The double
click on the new drive.
When
the hard drive opens, locate and open the
MP3. There will probably be a couple of sample songs, you can delete them to free up additional space if desired
Simply select and delete existing MP3s in the directory. Alternately, you can drag and drop MP3s into the directory to add them.
