20 Most Recent HP C6280 All-in-One Printer Questions & Answers
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
HP C6280... | Answered on Nov 05, 2015
Out of yellow ink?
If your ink is full, then you most likely have a dried up yellow ink path or the sponge at the bottom of the printer is full and preventing ink to pass through to the paper. Chances are, you are plugged up and need a new printer - HP is water based and if not used on a constant bases, the ink will dry and cause clogging.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
HP C6280... | Answered on Aug 05, 2014
Driver disk for what? You should just be able to plug this into a PC and install the drivers from the HP website without needing a disk of any sort.
They are available here
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&product=3194498
If you are not sure what your operating system is, go to the start menu, right click on computer, and choose properties and it should be listed
HP C6280... | Answered on Nov 21, 2013
Ok what is the issue.. are you not able to replace it or you are not able to remove it.
HP C6280... | Answered on Nov 07, 2013
Sounds like the settings may need to be checked. Are you sure there is no pieces of paper in the path? Also, did you change the density of the cards from what you used to use?
HP C6280... | Answered on Jul 24, 2012
If the alignment failed on HP Photosmart C6280, Try to check if any of the cartridges are low on ink. if so replace them and try to re-align
If that is not the issue, Remove the Cartridges from the printer and clean the contacts with lint free cloth and put them back in. The printer should go thru auto - alignment..
If this fails too, Press Cancel button on printer and Press the Menu button ( setup button ) and scroll to Tools menu - Press OK - Under tools option you will find Clean Cartridges - Press OK.
If this process too does not fix the issue, mostly likely your printer has gone bad. It needs replacement.
The best i can suggest you will be to Call HP support - 1-800-474-6836 and check best deal they can offer you on upgrade printer.
Regards,
Suhail
HP C6280... | Answered on May 20, 2012
yes you can use it but don't use the printer constantly for printing give him 5min rest after 50 prints
HP C6280... | Answered on Aug 04, 2011
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the printer off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate
good day
HP C6280... | Answered on Jun 16, 2011
Reset the printer:
With the product turned on , disconnect the power cord from the rear of the product.
Wait at least 15 seconds.
Reconnect the power cord to the rear of the product
Remove, clean, and reinstall the printhead
remove ink cartridges
Figure 22: Lift the latch handlec01481823.jpg
Lift the printhead straight up to remove it.
Figure 24: Three areas to cleanc01481825.gif 1 - Plastic ramp on the side of the ink nozzles
  1. Figure 29: Clean the electrical contacts inside the productc01676244.gif
  2. Dry the area with a clean, dry, lint-free cloth.
Reinstall the Printheads and the cartridges
Reset the product
It should work otherwise try to replace the Printhead and instead change the entire printer its time to change it
HP C6280... | Answered on May 06, 2011
To install the HP printer if you do not have the disc, follow the information from this link.
HP C6280... | Answered on Apr 19, 2011
HP C6280 All-in-One Printer Logo
85 questions posted
Ekse
efs_perpends
efs_perpends
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
windows ink cartridge empty false error
  • Office Equipment & Supplies
