20 Most Recent HP LaserJet P2055d Printer Questions & Answers
  1. The steps below are for changing the printer's language from the control panel or the web services.
  2. Remove the protective film on the printer's control panel to enable full response from the control panel. If you have not installed the printer software, go to the manufacturer's website and type the printer model, and click Begin. In the window that prompts you to download the printer driver, click Download. Now click Run, Save or Open, whichever is displayed on the window.
  3. Open the Downloads folder and give a double-click on the driver file. Follow the prompts to complete the setup and installation. When the 'Information About Your Printer' screen opens, select Edit. Select a language from the list of languages and complete the printer registration and activation on the manufacturer's website.
  4. If you want to change the language through the Embedded Web server (EWS), swipe the display to the left and tap the Setup icon on the printer's control panel. Select Tools followed by the Network Configuration report. Wait until the printer prints the Network Configuration Page.
  5. Locate the URL for EWS on the page and type the URL on your browser. Hit Enter to open the EWS page. Open the settings menu and select Preferences. Now click on the International icon to get access to all the international languages. Click the Control Panel Language option, choose your language and then select Apply.
  6. To set language from the printer's control panel, carry out the instructions given below. Power up the printer and tap the Setup icon. Select the Preferences option and open the Language menu. You will now see a list of supported languages. Tap on the language you prefer and then confirm your choice by tapping Yes.
HP LaserJet... | Answered on Dec 18, 2018
how can mirror print on HP laserjet p2055d
HP LaserJet... | Answered on Feb 19, 2017
try giving ping command to the ip of the printer
if you get a reply from the printer in the command prompt then the printer is properly connected to the network. for a precaution try to switch off the printer and if then too you get a reply there is conflict with the same ip.
if you get a proper reply from the ip try installing the driver once again
HP LaserJet... | Answered on May 03, 2016
Print the configuration page of the printer and it should list the IP address.
HP LaserJet... | Answered on Aug 03, 2015
The black cartridge may be exhausted or defective. Try erasing the paper count in printer menu
HP LaserJet... | Answered on Aug 01, 2015
I had the same problem. Try adjusting the setting to fit on one page (did not work for me on my hp but worked on my brother MFC) or remove the device and reinstall with updated drivers
HP LaserJet... | Answered on Feb 14, 2015
Hi, remove the toner cartridge out of the printer then remove the jammed paper.
HP LaserJet... | Answered on Feb 11, 2015
replace cartridge or clean the grunds that togh it
HP LaserJet... | Answered on Nov 22, 2014
Any 10 error on an HP indicates a problem with the memory chip on the cartridge. Try another cartridge if you have one.
HP LaserJet... | Answered on Sep 23, 2014
Hi, the output sensor is located on the output paper.
you can verify that it has a black wing
HP LaserJet... | Answered on Jul 15, 2014
We have found this error is not related to the cartridge area. We found that the exit flag spring in the back of the fuser is wound to loosely. Carefully take the spring while it's in place in turn it one full turn tighter. You will need a hook for this procedure or a bent paperclip. Resecure the end of the spring and bend the tip so it does not unwind. For good measure place a small amount of glue on the end of the spring. Our customer has about 100 of these machines in 10 of those were giving the jam and cartridge area message. After performing this procedure on all 10 we never had another issue with the machine
HP LaserJet... | Answered on Jul 02, 2014
HP LaserJet P2055d Printer Logo
181 questions posted
Ekse
efs_perpends
efs_perpends
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp laser jet p2055d printer command
  • Office Equipment & Supplies
