20 Most Recent Insignia NS-24LD120A13 24in 1080p LCD HDTV / DVD Combo Questions & Answers
Make sure it is powered on. Press power-on button then try to eject. If not, then press the power-on button and try to eject. If neither works, return to the sore or website where you bought it and ask for replacement.
Insignia... | Answered on Dec 26, 2017
Do a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
If a hard reset do not help you, its main system control memory IC is faulty, and should be replaced. Contact any service technician.
Insignia... | Answered on Nov 09, 2014
If they are remotes that came from another television, you can't. They are specific to that set.
If they are Universal - All for One remotes, you can reprogram them.
It is better to buy remotes SPECIFIC to the Insignia model you have. Google 'make model replacement remote', and you will end up somewhere like here.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&biw=1920&bih=937&tbm=shop&sxsrf=ALeKk03SbpJws_oC5yVlrPYcYx12u9KANw%3A1612380237750&ei=TfgaYP-eLavk5NoP6c-R8AE&q=insignia+tv+remote+codes
Insignia... | Answered on Feb 03, 2021
This could be a lot of things. It might be a cable inside or outside the unit. It may be an edge connection inside on the LCD panel. It may be the boards inside the unit.
Insignia... | Answered on Dec 26, 2020
panel problem
Insignia... | Answered on Dec 06, 2020
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
https://homehol.blogspot.com/
Insignia... | Answered on Nov 28, 2020
My insignia tv in the bedroom has no signal. It was working fine till I undid the cable in the living room. Moved the tv in the living room ...reconnected it. And now no signal in the bedroom.
Insignia... | Answered on Sep 19, 2020
Make sure that the audio cables are properly connected for the source (component, composite video or VGA/DVI (computer or other device)). Disconnect any cable in the headphone port.
Was the TV ever used with an audio receiver? If so, the TV speakers may have been turned off. Go to the Home Menu. Go to Settings > Display and Audio > Audio Output > TV Speakers and set this to On. (For Quick settings, press and hold Home. Then go to Sound > TV Speakers and set to On.) If you have a universal remote, the remote could be set to give all audio commands to a receiver. Try the remote so the Audio commands go to the TV. (This will depend on the remote. Please add a comment with the remote brand, model and type (often inside the battery compartment) for the full programming information.)
If you are using external speakers with a receiver, you may need to change the audio settings to PCM for a digital audio output. (This is in the same Audio Output section of the standard menu.)
I hope this helps.
(I've locked several remotes to the audio system which causes this type of problem when the home theater system needs a wiring repair.)
Do a factory reset to this set, and then check. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
https://remotesearch.blogspot.com/
https://electrohelponline.blogspot.com/
https://electronicshelponline.blogspot.com/
https://homenol.blogspot.com/
Insignia... | Answered on Jul 23, 2020
You are better off not trying to locate a schematic. Manufacturers dont release that information any longer. There is no market for it when parts can just be swapped and not subjected to troubleshooting and component replacement.
Insignia... | Answered on Jun 19, 2020
Check the control voltage that comes to the backlight inverter board. If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Insignia... | Answered on Jun 02, 2020
Insignia NS-24LD120A13 24in 1080p LCD HDTV / DVD Combo Logo
7 questions posted
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
dvd stuck in player will not eject
  • Televison & Video
