20 Most Recent HP Pavilion 6736 PC Desktop Questions & Answers
What button do i push to boot up
There should grey button on the front panel(see link to image)http://i.imgur.com/raD4l.jpgIf the PC doesn't fire up after pressing that button check your power cables in the back of the machine.
1/4/2013 8:46:19 PM • HP Pavilion 6736... • Answered on Jan 04, 2013
I would like to up graded my graphic card what
you got just 3 pci port no agp no pci express port....so is a litlle imposible to upgrade you video card
9/22/2011 1:56:24 PM • HP Pavilion 6736... • Answered on Sep 22, 2011
Hello, we have a HP
Here is a link to the HP Online Support page for your model of PC:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=46136&prodTypeId=12454&prodSeriesId=46136&objectID=bph06111
As you can see from the specs listed there, your model did not include a wireless card from the factory.
Adding one yourself though is quite easy.
You can get an actual wireless card that you plug into an empty slot in your motherboard (inside the case of the computer) which requires a small amount of screwdriver work.
Or you can buy a Wireless USB Adapter which is a small device the size of your thumb which plugs into any USB port on your computer. These are very easy to install, just insert the CD which comes with the unit, run the installer program on it and follow its instructions. Then just plug the adapter into any open USB port on your computer when it tells you to. Thats pretty much it.
The USB adapter is good because you can move it easily from one computer to another if you want without having to open up the computer case.
Anyway good luck and please comment back and rate if this was helpful at all.
2/13/2011 4:59:29 AM • HP Pavilion 6736... • Answered on Feb 13, 2011
My hp pavilion 6736 computer
It is probably getting a stop error and automatically restarting. You can stop this by hitting F8 rapidly after you power on. If you do it properly you'll get a black and white screen. One of the options is:
  • Disable Automatic Restart on System Failure
Choose that one.
Now when you get an error, the system won't reboot and you can find out what is causing your failure.
8/14/2010 8:29:29 PM • HP Pavilion 6736... • Answered on Aug 14, 2010
3answers
Can I install a hard drive in an HP Pavilion 6736
The size is not an issue with the hardware normally. Usually it has to do with the operating system. If you are running an OS like windows xp you should have no problem.
Just make sure you are using the SAME type interface hard drive. Example PATA Parallel ATA, or Serial ATA (SATA).
5/4/2010 6:53:34 PM • HP Pavilion 6736... • Answered on May 04, 2010
Need to install a new hard drive on a HP Pavilion
in most PCs the MB and cables inside will have provision to add
2 HDDs
2 Drives (CD or DVD)
1 floppy drive(now it's obsolete)
in a IDE system the data cables inside will be aprox 3 inch wide and the MB will have 2 IDE slots to fix the cables....
in a SATA system the data cables inside will be aprox 1 inch wide and the MB will have 4 SATA slots to fix the cables....from 2 HDD and 2 Disk Drives....
you should know how to install a new HD and make it primary or slave depending on which HD has your OS...
google and find more details on that...
5/4/2010 5:15:18 PM • HP Pavilion 6736... • Answered on May 04, 2010
How do I get to the memory sockets on an HP
1) Computer unplugged from Power
2) Viewing the rear of the computer case there is a Thumbscrew you loosen. It is on the Left side, approximately half way up. Doesn't come all the way out. (Shouldn't)
3) Above the thumbscrew you will see a 'Bump' in the side case cover. This is a place to put your fingers, when pulling back on the side panel.
Thumbscrew loosened, pull back on the side panel. If memory serves the side panel only comes back so far, then it is lifted up, and out.
If I may;
BEFORE you reach inside your computer, I advise you should follow some simple Anti-Static guidelines.
Your body carries Static electricity.
Static electricity will FRY out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, computer case open, TOUCH the metal frame of the computer case.
That's it.
This will relieve your body of Static.
Should you get up for any reason while working on your computer, leave, then come back, Touch the metal frame again.
Touch the metal frame before, you take the new ram stick/s out of their protective anti-static bag/s.
If you are already aware of the above, please disregard it.
Regards,
joecoolvette.
(In case my solution explanation was not clear enough, here is HP Support, and how to open the computer case style you have,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00968217&cc=us&lc=en&dlc=en&product=3872247
1/8/2010 9:34:01 AM • HP Pavilion 6736... • Answered on Jan 08, 2010
I have email error 99999
delete and reinstall your email software.
6/25/2023 8:52:09 PM • HP Pavilion... • Answered on Jun 25, 2023
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
11/30/2022 7:10:30 AM • HP Pavilion... • Answered on Nov 30, 2022
How do i get mywindows keyboard to work
desktop or laptop. ? external Keyboard or internal
6/9/2022 10:54:32 AM • HP Pavilion... • Answered on Jun 09, 2022
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
6/2/2022 6:19:00 PM • HP Pavilion... • Answered on Jun 02, 2022
Hp pavilion entertainment pc 17 sd ms pro mmc xd
HP.COM << go there. And ask a real question ,you did not.
5/25/2022 11:36:13 AM • HP Pavilion... • Answered on May 25, 2022
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate. this is no secret,gee millions sold. A6Y530A the partsurfer shows true model, and fails this is the only post here ever asking for reverse code lookups on models fake, and is not easy in vast cases I guess you have no such PC, (look like) so why ask this>? what prompted this quest>? not told why not ask seller for photos of it if this is a pre sales question , is it>? google and bing and HP all show that model # is BOGUS so go back to your sell and ask the we can not guess PCs ever. HP product ID# is best on the service tag for SURE. where did you see this number, not told. or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits. you posted to HP forum, (not real) Hp.com is real
5/2/2022 12:59:02 PM • HP Pavilion... • Answered on May 02, 2022
Hp pavilion g series manual
what does not working mean (KBD) dead, or 1 key bad or row. what? symptoms matter most, for sure in a LAPTOP IS IT the word Pavilion is on laptops and desktop, dig? G mean zero , the service tag does not just say "G" sorry. easy peasy lemon squeezy HP.com complex URL no? go there tell them your model # or better the service tag code ! . then magically HP puts you on YOUR service support page and all manuals and all driver before your eyes. amazing no? NO told at all or of a laptop or desktop or what./? you posted ANON so I can't just read other posts by you to learn what PC this is , no I can not. there are over 100 PC called G series, and vast years. some PCs by them G1 to 7 are generations, like HP Pavilion g6-1029tx Notebook. if you can find the service tag the product ID # is what matters most this code includes (real model, version , options and country sold) see this, older PCs by them had this. see that , all matters but do not post SN/ or service codes in public. mine: procuct code (nnnnnnABA#) https://www.pcdied.com/TAG-jive/tag-elite8540w.JPG I will guess it is 17" laptop, here is the mess just that 1 sized once you see this you know that G series means not MUCH> https://search.brave.com/images?q=hp+G+series++pavilion++17%22+G&source=web
5/2/2022 12:17:49 PM • HP Pavilion... • Answered on May 02, 2022
The airplane mode button is stuck on orange although my computer say's airplane mode off
old PCs do that, for many reasons. but no PC told at all just HP. 40 years of PCs ,10000 + models nobody can guess ever. but I do have the answer, in pure generic form. did you buy the PC like that used and bad Wifi. ?
  1. the wifi card is missing, as was super common 10+ years ago.
  2. someone put in the wrong card, not from HP list
  3. HP blacklists (bios blocks) none HP cards (wifi)
  4. the card needs a driver to work if not it is dead or 1/2 dead.
  5. the PC needs 1 more driver to make the wifi buttons all work , all buttons related, if not they are dead or act odd.
  6. The OS is infected, no OS told at all, not one clue nor if upgraded the OS, and not vast drivers are wrong or missing, (classic)
Im sure this this is not the free w10 upgrade, if it was that too kills drivers dead, for sure HP told you this unstated PC will not run W10 and has zero support from HP, on w10 AS YOUR SUPPORT PAGE WILL DISCLOSE TO YOU AT HP.COM
5/2/2022 11:38:43 AM • HP Pavilion... • Answered on May 02, 2022
Fix pdf handler
today there are many PDF , Viewers not juts Adobe ! google finds them like this. https://www.google.com/search?q=pdf%20viewers
5/2/2022 11:25:45 AM • HP Pavilion... • Answered on May 02, 2022
How reinstall bios on a HP dv9000
bad news now your bricked it just like miillions did google bios update bricked my PC and cry. why are you here and not at HP.com only they can recover bios. they changed the rules now 10 time. so only they know this, and are pain to deal with. UEFI is the enemy here, new rule and regressive as can be. in fact all new PCs can not be regressed, and some old now they even delete the 20 version of bios there, to force that. not saying they did that to your PC, but keep that in your head on all HP PC. the last bios upgrade stated, no going back. the Cntrl_+B might work , the flashback bios trick\ in your manual if you read it.
5/1/2022 4:52:54 PM • HP Pavilion... • Answered on May 01, 2022
How do i remove the tuvaro virus ?
nobody can we erase all and reload the OS fresh. did not say you can not try but that 99 out 100 will fail.
5/1/2022 4:42:46 PM • HP Pavilion... • Answered on May 01, 2022
How do i diagnose/test and repair my laptop
100% dead black screen no text or HP SPLASH screen now. The problem is hardware where we buy hardware for free, less than at deity level or a thief. you tell me.... no PC told at all not one tiny clue of 1000s of HP models for 4decades are we to guess models and lie to you? now the GENERIC answer USA PCs only sorry I do not do others. fans dead? no beeps> codes no Caps lock key blink codes. no text errors.? 1: does PC run BIOS pages if huge now shorted old relic battery is removed ,yes bingo 1. 2: is the RTC coin cell dead, ,Bingo 2. a $1 uSD ,USA cost. here. 3: the pre 2010 all have bad CCFL lamps; do this flash light test? https://www.pcdied.com/monitors_and_screens/flash-light-trick.html#flashlighttest if yes, that is a $50 to $100 USD parts repair , labor more. repairs are serial process, as fixing one thing bad ,uncovers the next this is how mans machines work just like that. NO PC told, NO PC told,NO PC told,NO PC told,NO PC told,NO PC told,NO PC told, all I can do is BEG,
5/1/2022 4:34:40 PM • HP Pavilion... • Answered on May 01, 2022
HP Pavilion 6736  PC Desktop Logo
8 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
install hard drive in hp pavilion 6736
  • Computers & Internet
