20 Most Recent Rheem 13PJL24A01 2 Ton 13 SEER Heat Pump Air Conditioner Questions & Answers
Please see your other post.
Rheem 13PJL24A01... | Answered on Nov 25, 2013
If you're comfortable working around electricity then you might try trouble shooting a few things. Most HVAC (heat, ventilation, air conditioning) systems have a window which you can view the circuit board and a blinking led light. The number of blinks corresponds to the error code that is occurring. Some models have an explanation on the inside of the removable access panel. A few things to check for: Does the ignitor glow on start up? If not, the blower will start but then shut down. No glow, no ignition, the safety feature will not allow gas to flow. At that point, check the ignitor, it will be the cheapest to replace. If it glows, I would then check the sensor probe. If the sensor probe does not detect heat (or it went bad) then gas will be shut off for safety. After that, then I would move to checking the Controller Board. This is a little more involved and more expensive. But it really depends on how adept and handy you are. Good luck.
that reset is for the high pressure switch. this means your compressor is getting to hot which is then increasing the pressure and tripping the switch because the fan isn't running. usually if a capacitor is bad you can give the motor a "kick start " and the blade will then start turning. use a long stick or screwdriver to spin the blade but then you will know you need a cap. that switch is protecting your compressor, don't hold it down to keep it running.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Rheem Heating &... | Answered on Oct 14, 2017
Likely a bad motor. If you have a meter and electricity confidence you need to verify that you have high and low voltage AT the motor. If both voltages present and still no motor you know it's bad. If no low voltage, possibly have a bad control board.
Rheem Heating &... | Answered on Sep 16, 2017
no it is a straight a/c cooling only unit
Rheem Heating &... | Answered on Mar 10, 2016
Rheem 13PJL24A01 2 Ton 13 SEER Heat Pump Air Conditioner Logo
3 questions posted
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
ray gallant
 Russ Hill
Russ Hill
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Rheem Heating & Cooling
Most Popular Question
no heat but fan running
  • Heating & Cooling
