20 Most Recent Rheem 13PJL30A01-RHLLHM3617JA 2.5 Ton 14 SEER Heat Pump Air Conditioner Split System Questions & Answers
it is located on the control board inside the air handler
Rheem... | Answered on Mar 10, 2016
When any unit 1st come's on, you'll always have some cold air that's in the ducts that will blow out before you get warm air. If your duct work is uninsulated in a cold basement or crawl space then it will be even more noticeable. When the unit is heating from the Heat Pump mode, it takes a little longer for the gases to get warm enough so you'll fell heat. When it gets cold enough for the unit to switch from heat pump to the gas or electric heat source, you'll get warm air faster. If you have gas heat, some Thermostats have an anticipator setting for the gas valve. If it's set wrong it will effect the on/off cycle of the gas valve.
All duct work in non heated and a/c spaces, including inside walls,above dropped ceilings, in attics and crawl spaces, must be sealed & taped at the seams and joints and then insulated and taped.
Most new construction has solved that problem with insulated duct board, flexible insulated supply's and special tape.
Rheem... | Answered on Dec 12, 2013
There is a short somwhere in the low voltage circuit. Test the continuity of the remaindimg wires to ground, you should have no resistance, if you do have resistane the wire will have to be replaced. Also, the thermostat can have an internal short which can cause the fuse to blow.
Rheem... | Answered on Jan 09, 2013
that reset is for the high pressure switch. this means your compressor is getting to hot which is then increasing the pressure and tripping the switch because the fan isn't running. usually if a capacitor is bad you can give the motor a "kick start " and the blade will then start turning. use a long stick or screwdriver to spin the blade but then you will know you need a cap. that switch is protecting your compressor, don't hold it down to keep it running.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Rheem Heating &... | Answered on Oct 14, 2017
Likely a bad motor. If you have a meter and electricity confidence you need to verify that you have high and low voltage AT the motor. If both voltages present and still no motor you know it's bad. If no low voltage, possibly have a bad control board.
Rheem Heating &... | Answered on Sep 16, 2017
Rheem 13PJL30A01-RHLLHM3617JA 2.5 Ton 14 SEER Heat Pump Air Conditioner Split System Logo
8 questions posted
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
ray gallant
 Russ Hill
Russ Hill
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Rheem Heating & Cooling
Most Popular Question
3amp fuse in rheem ac unit
  • Heating & Cooling
