20 Most Recent Rheem RPQL060JEZ-RHLLHM6024JA 5 Ton 14.5 SEER Heat Pump Air Conditioner Split System Questions & Answers
Replace the fuse with a light bulb. You should be able to take some measurements now to find the fault.
Rheem... | Answered on Sep 16, 2017
that reset is for the high pressure switch. this means your compressor is getting to hot which is then increasing the pressure and tripping the switch because the fan isn't running. usually if a capacitor is bad you can give the motor a "kick start " and the blade will then start turning. use a long stick or screwdriver to spin the blade but then you will know you need a cap. that switch is protecting your compressor, don't hold it down to keep it running.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Rheem Heating &... | Answered on Oct 14, 2017
Likely a bad motor. If you have a meter and electricity confidence you need to verify that you have high and low voltage AT the motor. If both voltages present and still no motor you know it's bad. If no low voltage, possibly have a bad control board.
Rheem Heating &... | Answered on Sep 16, 2017
no it is a straight a/c cooling only unit
Rheem Heating &... | Answered on Mar 10, 2016
check your air handler overflow pan and check to see if it is full of water. If so, you need to unclog the normal drain and remove the water in the overflow pan, once level is low enough the float switch will reset and control power will start unit up again.
Rheem Heating &... | Answered on Feb 11, 2016
This will be dependent on the capacity (tonnage or BTU/Hr) of the condenser, its location and how much refrigerant will be needed to added / replaced - plus the labor to do it. A typical 2 - 3 ton residential system (air handler / condenser - no duct work, etc.) can run $2k and up.
Rheem Heating &... | Answered on Nov 09, 2015
Rheem RPQL060JEZ-RHLLHM6024JA 5 Ton 14.5 SEER Heat Pump Air Conditioner Split System Logo
1 questions posted
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
ray gallant
Marat Brikov
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Rheem Heating & Cooling
Most Popular Question
keeps blowing fuse 3 amp circuit board
  • Heating & Cooling
