There are two ways to solve the problem:
First solution:
* Reboot the PC. While it is being restarted by pressing the F8 function key. On the screen will display a different kind of start (If we do not even get the pc reboot and press the F8 function key faster;)
* Select "Start in Safe mode"
* When you are prompted to log in using the local administrator account
* Go to services and DISABLE everything that starts with HP
* Reboot the system. Hit f10 while it's starting and disable the security settings (the second colum halfway down). You'll have to configure a password to do it for some reason.
* Go to Start / all program / HP ProtectTool Security Manager FOR ADMINISTRATORS
* Click on Credential Manager and then click Settings
* Deselect the checkbox in the General tab "Use credential manager to log on to Windows"
* You need to logoff
* Select "Logon as a different user" and use a standard domain account.
Second Solution:
At the Windows login screen, do the following:
* Choose "log in as different user"
* Click "log on with Wizard".This will bring up a new login window where you can specify you username, Domain, and password.
* In the bottom left corner of this window is a button labeled "More" Click it, and check the box labeled "Do not logon to Credential Manager"
* Write your username, password and domain in the respective places and log on.
* After successful logon, UNINSTALL CREDENTIAL MANAGER!
If you don't, you will have to repeat the procedure next time you start up your PC again!
Sometimes this solution will works fine:
* Start in safe mode and log on as a local admin
* Start device manager and look under 'Security Devices' for 'TrustedbPlatform Module' - Right click and select uninstall
* Reboot and allow the module to auto-reinstall itself
You should now be able to logon to Windows without receiving a credential manager error. Depending on the versions of Windows you are running you might have to re-register any finger scans you had stored. The problem is the driver becomes corrupted. If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
