20 Most Recent
Lenovo ThinkPad T500 Questions & Answers
How do change the HDD
Go to YouTube and look it up, most likely its in a side compartment that pops out like the CD player does.
How do i reset a Lenovo Thinkpad T500
Reset could mean one of several things. I assume you know how to simply reboot it. If it is hung you can hold the power button down for about 6 seconds to turn it off.
If you forgot the password, contact Lenovo support at
http://support.lenovo.com/en_US/
Provide them with proof of purchase and original receipt to prove ownership of laptop.
If you want to restore factory defaults then installed on the ThinkPad T500 is a program called Rescue and Recovery, which helps you diagnose and fix problems with the Windows operating system. To access this software, reboot your T500 and press the oval-shaped blue ThinkVantage button -- located on the upper-left area of your keyboard -- when the ThinkPad logo appears. When the Rescue and Recovery menu appears, choose the option that describes what you want to do. Follow the directions on the screen to run the appropriate action.
If you need the recovery disks then try
https://ez93.com/dl/lenovo-t500-restore-factory-settings.html
Hello - I had a Thinkpad 2 by Lenovo. It came
- Did you look at the buttom of the pc. Might be a serial number or something similar.
- There should be a back up drive (drive Z: I think it's called, it has the pre installed programs).
- If there isn't any Z: drive, then you should have been given some CD's or DVD's when you bought the pc. They should have the program as well.
Bios password locked
please flash the bios.......wid this software.....click the link and download it...then install it....yaa...why not.......The 64 bit link is...------ http://download.lenovo.com/UserFiles/Driver/en/Downloads%20and%20Drivers/Z460Z560/BIOS/29CN38WW/NIWEx215_X64.exe.
I need a driver of my pc model ni 0769-A29,Serial
Goto to this link below
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=10&familyind=422608&operatingsystemind=49979&template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&validate=true
in Brands Select : Notebooks and Handhelds
in Family Select : Thinkpad T500
in Type Select : All Types
In Operating system Select : the Operating system you installed.
And download the drivers.
Rate this answer.
Dear There,
I have Lenovo ThinkPad
Two things. You might have a problem with the inverter or with the backlight lamp.
You need to open your Laptop Screen. Normally the screws are hiding underneath the rubber stops. It would be better if you can find a LCD disassembly manual for your laptop else just write down what and account everything that you do. Check for the Fluorescent like lamp if its burnt out. If it is then you need to replace that. If not, then you need to replace the Inverter(a long rectangular shaped circuit board. Normally it is just at the bottom of the LCD screen.) Note the product code written on the inverter and order it. This should fix that problem.
Battery light flashing orange
It means that the battery not taking the charge. Do you know how old is your battery? The battery life span usually is only 2 to 3 years.
Thanks
