20 Most Recent BenQ DC E300 Digital Camera Questions & Answers
When you installed the driver do you have connect the camera to laptop, if the laptop cant't find the camera be connect to laptop when you installed the driver it will failed. Else, as to save life of your camera, suggest that to use card reader instead of connect camera to laptop.
BenQ DC E300... | Answered on May 25, 2012
Hi Beshoui,
I believe your zoom lens is not extending when you power on. In most cases like this, there is likely a foreign body (sand) or similar objects lodged between the lens tubes or the camera has been subjected to a knock (dropped, bumped against a solid surface) that caused the lens tube to miss-align. All you need to do is:
1. as you switch on the camera, give a little knock/ tapping with your fingers around the lens.
2. if that fails, apply a little pressure to the sides of the lens ring while powering on your camera.
Lets hope that will help to dislodge the foreign body or the lens tube miss-alignment.
BenQ Cameras | Answered on Feb 08, 2016
Please.
When an electronic device is start acting strange, a software update is the worst thing you can try to solve the problem.
Updates are only allowed if the system is working without an error.
If it is not working correct, you can't be sure it will load the update correct and you never know what happens when the update is started.
For every update there is a condition, the electronic needs to work perfect and the battery / power supply must be capable of delivering enough power during the whole update process.
I'm sure there will be no update for the Benq camera.
BenQ Cameras | Answered on Jul 27, 2014
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
BenQ Cameras | Answered on May 13, 2014
Always when your camera acts strange, switch it off. Wait a few seconds, till you are sure it is not accessing the memory anymore. Then remove the battery (ies). If possible first charge the battery (ies) Than replace the battery and switch on the camera. If the error comes back, you have to assume something serious is going on. In which you should contact a service centre or repair shop.
BenQ Cameras | Answered on Jan 29, 2014
BenQ DC E300 Digital Camera Logo
12 questions posted
Top BenQ Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Daniel Dollive
Daniel Dollive
Are you a BenQ Camera Expert? Answer questions, earn points and help others
View Most Popular
BenQ Cameras
  • BenQ Cameras
Most Popular Question
benq dc
  • Cameras
