20 Most Recent Sumvision Yumi Pro Digital Media Player Questions & Answers
Vista compatibility problems
Copy the installation to your hard drive.
now take the properties and setup it for windows xp under the tab compatibility.
now run your application with administrative privilage. right click then "Run as Administrator'
Vista's Compatibility assistant is known to have a lot of bug.
if it didn.t work then
Press the keyboard combination "Windows Key +R"
you will have run dialogue box
type in "services.msc"
in the window that appears look for "Program compatibility assistant" and then disable it.
now restart your computer and try installation
it will be fine
its recommended that you switch your os to windows 7 from vista as windows 7 is more bug free and crash is unlikely to happen
1/8/2010 10:19:45 PM • Sumvision Yumi... • Answered on Jan 08, 2010
Sumvision sv-245s manual
245s rar is the link for the manual. You will need a .rar file decompression program such as WinZip to open it.
8/6/2017 5:08:11 AM • Sumvision Audio... • Answered on Aug 06, 2017
Sumvision cyclone mkv 2 enclosure will not conect
From this and several other posts you made on this device (I assume you are the same Anonymous poster), it appears you do not have a formatted hard drive installed in the unit, or you didn't know the computer is treating it as an external drive (even if it calls it an "unknown" USB device. Your computer is looking for the file system in the enclosure. The directions for finding the unit from a Windows computer (written for the mkv, not the mkv 2, but they would probably work the same) are given in the review article linked below. Note: if you don't find any "Unallocated" disk, look in "My Computer" for a drive that isn't your internal hard drive or other usual device. Probably all you have to do is save your media files to this drive and they will be available to play on your A/V system. Sumvision Cyclone MKV Primus 1080HD media player
8/6/2017 5:01:31 AM • Sumvision Audio... • Answered on Aug 06, 2017
Why after 5 months of perfect use has my Sumvision cyclone X4 come up with a screen with time and date and says "plug in charger" and requests a password ?
Refer to the user manual of your MP3 Player. More over it seems it require battery replacement.
4/5/2016 3:42:22 PM • Sumvision Audio... • Answered on Apr 05, 2016
0answers
Sumvision Cyclone Media Player - how do I get
hi
i have sumvision cyclone multimedia player. its not reading any files when im connecting to tv but works fine with usb
4/28/2010 3:59:28 PM • Sumvision Audio... • Answered on Apr 28, 2010
I have a cyclone media player thar once loaded
format with fat 32 make 3 new folders movies music photo drag folders into relavent folders this should cure the problem
3/7/2010 10:14:50 AM • Sumvision Audio... • Answered on Mar 07, 2010
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first. But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
4/16/2024 5:57:29 AM • Audio Players &... • Answered 10 hours ago
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
4/10/2024 6:11:44 AM • Audio Players &... • Answered on Apr 10, 2024
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
4/9/2024 1:32:47 PM • Audio Players &... • Answered on Apr 09, 2024
Sumvision Yumi Pro  Digital Media Player Logo
3 questions posted
Top Sumvision Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sumvision Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sumvision Audio Players & Recorders
Most Popular Question
vista compatibility problems
  • Audio Players & Recorders
