20 Most Recent Samsung SP46L3HX 46" HDTV-Ready DLP TV Questions & Answers
if all the tubes are lit then i would suspect from what you describe you have alge growth in one or all of you tubes. at the shop we would change the fluid called glycol., i rather involved procedure because once you remove the tubes then have to go through advance setup aligning them. We generally change all the fluid in all tubes although you can change in just one. The blue tends to be the one with the worst fluid problems.
Samsung SP46L3HX... | Answered on Jun 23, 2011
Tip
How to replace assy lamp
Before you replace the assy lamp :
1. Replace with the correct code numbered lamp to avoid damage to the TV.
2. Turn the power off and wait for 30 minutes before replacing the lamp as it will be hot.
3. Do not touch the glass part of the lamp with your bare hands nor insert any foreign object inside the cover as it may cause poor screen quality, electric shock or fire.
4. Do not place the old lamp near flammable objects or within the reach of children.
5. Be sure to connect this TV directly to an AC wall outlet. If the TV's AC plug is connected to a cable box or other source, it will not allow for proper cool down time.
To replace assy lamp on SP46L3HX follow steps :
1. Unplug the TV, then use a screwdriver to remove the 4 screws.
2. Remove the Lamp cover.
3. Remove the screw securing the Lamp by using a screwdriver.
4. Separate the Lamp from the engine by holding the handle and pulling it out.
5. To reinstall the Lamp, follow these steps in reverse order.
on Mar 31, 2011 | Samsung SP46L3HX 46" HDTV-Ready DLP...
First. Lamps can look ok in the center and still be bad. Install a new lamp since I do not know when you replaced the lamp or if at all. Turn on the set and at the same time look through the Lamp Door vent slots to see if the lamp Illuminates. If so your lamp is ok and the Color Wheel is bad.
Samsung SP46L3HX... | Answered on Apr 14, 2010
try cleaning your screen the holes
that you see on side of set is whear you clean.it
go to walmart and buy lcd cleaner and that should work.
but if still thear your eng block is bad
Samsung SP46L3HX... | Answered on Aug 12, 2009
That most probably seems to be a future issue with your color wheel, it's starting to go out, you need to identify which one you have before you purchase one, there are two kinds, one with a gold bearing and another one with a silver bearing
Samsung SP46L3HX... | Answered on Jul 24, 2009
Color wheel needs replacement
Samsung SP46L3HX... | Answered on Jul 13, 2009
If you've switched on your TV and the sound comes through fine, but you're not seeing any picture; there are 3 potential issues. No video with normal audio on a Smart TV will the result of one of the following issues: ? A connection issue; the most common problem. Where there is a bad connection, faulty cables or improper installation.
? An issue with the device connected to the TV. There may be a video output setting on the device that you must set properly before it will output to the TV.
? There is something wrong with the TV, which will require a technician to assess the TV and find a solution.
Samsung... | Answered 17 hours ago
Request the diagram from Samsung.
Samsung... | Answered Yesterday
Applicable code(s) would be in a compatible remote control
When a TV is showing vertical colored lines, a loose wire cable in the TV might be the cause. If you knock on the back of the TV, the vertical colored lines MAY disappear temporarily. This is a sign that a cable is loose or the T-Con board is faulty.
A black screen could just be a sign that the TV is turned off, although if it is producing sound then you know that's not the case. When your TV has a black screen even when it's on, it's quite possible it could actually be your external device and not your TV.
Samsung... | Answered 2 days ago
You seem to have solved the issue yourself!
If the Backlight issue has been resolved and you are sure they are not the issue then if the diffuser screens have been replaced in a different order or reversed then this is the problem!
To resolve it you should dismantle the TV and rearrange the diffuser screens and test before re-assembling the TV.
Samsung... | Answered on Nov 21, 2020
its very easy.
browse www.ifixit.com
there you will get all the information , solutions and codes.
thanks
When the LED backlights fail on the screen, the power supply shuts down to avoid an overload. You can replace the strips or if you are really motivated and have the equipment, you can test each LED and replace them individually.
Samsung... | Answered on Nov 20, 2020
1. Open internal fuse
2. Power supply failure
try a tv repair shop locally or buy a new set
Samsung... | Answered on Nov 19, 2020
Samsung SP46L3HX 46" HDTV-Ready DLP TV Logo
12 questions posted
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung dlp hl p4663w loud whistling
  • Televison & Video
