20 Most Recent Zebra ZM400 Direct Thermal-Thermal Transfer Bar Code Questions & Answers
Press Setup/exit first option should be Darkness.
Press Select then the plus key.
Press setup/exit twice to exit and save.
Zebra ZM400... | Answered on Jul 07, 2015
There must be a piece of debris in there.
Pull out the roll and examine closely with flashlight and magnifier.
And try blowing it out with canned air.
Zebra ZM400... | Answered on Jan 21, 2015
check the pressure of the printhead.increase the pressure of the printhead.
its a ribbon friction line.
Zebra ZM400... | Answered on Nov 22, 2014
The printer driver settings override the printer settings unless you tell the driver to use the printer settings. You can tell by setting the printer setting and saving it permanently. Print a configuration label. Send a label to the printer. Print another configuration label. Compare the config labels and If it changed, then the driver changed it. Set the driver as above and it will not change when you print.
Zebra ZM400... | Answered on Nov 06, 2013
Use a null modem serial cable . Match computer com1 serial port settings with printer serial port settings.
That is correct, you can try VM Windows. I would get a cheap laptop instead, as it is easier. Hope this helps!
Zebra ZM400... | Answered on Jun 21, 2011
http://www.scanonline.com/Online-Store/ZM400-600
Download the ZM400/600 Quick Reference Guide on the right hand side of the page. They have a diagram on how to load labels.
There should also be one inside the printer - printed on the back wall...
Zebra ZM400... | Answered on Jul 10, 2009
did you reset this printer to factory setting just visit this link http://blogs.scansource.com/zebra-zm600-how-to-reset-printer-to-factory-defaults/
if you have user guide plz flow that if you dont have it visit this link below
http://www.bluestarinc.com/techsupport/ZEBRA/Manuals/ZM400_600_UG.pdf
Zebra Z Office... | Answered on Jan 20, 2014
The Zebra ZP 550 will work with the GK 420t driver which is free for download at zebra.com. After installing it restart shiprush and your zebra printer will show up in your printer selection menu.
Zebra Z Office... | Answered on Dec 19, 2012
https://www.youtube.com/watch?v=h_adsY2TOv4
Zebra Office... | Answered on May 03, 2020
Zebra ZM400 Direct Thermal-Thermal Transfer Bar Code  Logo
16 questions posted
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Z Zebra
  • Z Zebra
Most Popular Question
load new labels
  • Office Equipment & Supplies
