20 Most Recent Samsung SCX-4500W WiFi Multifunctional + USB Cable A male / B male 1.80m + USB 2.0 7-port Hub Laser Printer Questions & Answers
Failing being able to track down software, which may be on Samsung's website, what about importing the scanned images into Word, then exporting to PDF format?
My Samsung M/F does not have the feature, that I've seen.
I either use the Word load image>export PDF method, or SCRIBUS, which is more of a 'Publisher' app, allowing text and image frames to be resized and moved around.
Except SCRIBUS does only a single page for flyers/menus etc.
Samsung... | Answered on Dec 19, 2017
I had this problem of the printer reportings "Corrupted Data" on a Samsung CLP-300 and a Samsung MPL-1910 printer and found a software setting that resolves the issue. I only found this issue on Windows 8.1 but I'm not sure it's Windows OS related. I just hadn't had this problem on Windows 7, Vista or XP. My printers are all on my home network connected to print servers so use TCP/IP ports on the laptop.
Go to the Printer Properties menu and select the "Ports" tab (3rd from the left near the top of the menu box.
Select "Configure Ports..." within this tab
If you have "RAW" selected then select LPR.
I added a Queue Name to match the Print server but I'm not sure if this is required
Then click OK and then you'll be returned to the Printer Properties Menu box.
Select the "General" tab on the extreme left of the tabs and click on "Print Test Page"
If you get a "WIndows Printer Test Page" out then this has resolved your problem.
I notice that it still reports on the Test Page that the format is RAW but now it works fine.
Samsung... | Answered on Oct 06, 2017
You might have a paper jam ... For a most accurate diagnosis you might use control panel app from samsung website
Samsung... | Answered on May 18, 2014
Tip
Samsung SCX-4500W restore wireless printing on cryptic error
For those having trouble wirelessly printing to their Samsung SCX-4500W printer from a Windows computer, I have this "easy" 13-step process that usually fixes my most common printing problem:
The symptom:
You haven't used your printer in a couple of days and have just hit the print button in an application you wish to print a document from. Instead of your printed document gracefully emerging from your printer, a Samsung status window appears on your computer above the task tray, cryptically announcing "The current printer port is not supported for the current printer status". You scratch your head in complete confusion.
The solution:
  1. Go into the room where your printer is. Observe that it has dropped its wifi connection and not reconnected automatically - the blue light indicating wifi is no longer illuminated.
  2. Turn off the printer, wait a few seconds, and turn it back on.
  3. Rebooting always causes a blank page to be ejected - how annoying! Open up the tray and reinsert the blank sheet.
  4. Wait for the blue wifi light to come on.
  5. Return to your computer and open the printer job queue window. Locate your document in this window with "Error" status next to it: right-click on it and select restart so its status changes to "Printing".
  6. After a while, notice the status has changed to "Error - Printing" or "Error - Sent to printer". Since restarting the job was not successful, right-click and select cancel. Press the OK button in the confirmation dialog. You may have to do this a second time before the job clears.
  7. Return to the application you printed from and re-print the document.
  8. Double-click on the blue Samsung "S" icon in the task tray. A window titled Samsung SX-4500W Series will appear in the lower right. Observe the status first says "Please wait..." then show the same cryptic message "The current printer port is not supported for the printer status". Grrrr.
  9. Check if your computer really can access the printer by opening web browser and typing its ip address. For me, it is 192.168.1.70. Alternatively, click the "Printer Setting" button in the window of step 8. Observe that the printer reports it is alive and ready for action. This is good.
  10. Check if any other Samsung software is able to use the printer: Open SmarThru 4 software, select "Scan To", "Folder", then hit "Scan" button. Observe that scanning from the printer works absolutely fine. Close SmarThru. So the problem is just the crappy printer driver.
  11. Close any Samsung windows you have open. Navigate the start menu to Samsung SCX-4500W Series->Maintenance. The installer will run in maintenance mode and find your printer on the network (and show its ip address), as well as an option to use it on "Local Port". Select the printer on network and click Next. Select "Samsung SCX-4500W Series printer driver" to repair and hit Next. The driver will re-install. Click Finish when done.
  12. Return to your application you wish to print from and activate the printing of the document again.
  13. The Samsung status window will once again appear in the lower right proclaiming "The current printer port is not supported for the printer status". Ignore this stupid message and close the window. Go to the room with your printer and with any luck, you will find your printed document waiting for you!
Once you are well practiced at this, and can fully appreciate how useless Samsung's software developers are, you can just do steps 1,2,3,4, 5, 6,11,12, and 13.
on Mar 09, 2011 | Samsung SCX-4500W WiFi...
HI PLEASE CLEAN THE CCDUNIT .YOUR PRINTER CCD UNIT IS VERY LOTS OF DEST.AFTER CLEANING CCD THEY PRINT SAMSE SO REPLACE CCD UNIT WITH CABLE
Samsung SCX... | Answered on Dec 02, 2019
go directly to Samsung to download driver
http://www.samsung.com/levant/support/model/SCX-4828FN/XSG-downloads
Samsung SCX... | Answered on Apr 02, 2019
Samsung service code is fn # 1934, go to tech mode and reset to factory set
Samsung SCX... | Answered on Jan 26, 2019
It has no built in duplex function only manual duplexing. Print the odd pages first than turn them up and print the even pages.
Samsung SCX... | Answered on Apr 14, 2016
your printer high voltage power supply board voltage is not correct .so please check the hups board
Samsung SCX... | Answered on Oct 24, 2015
Samsung SCX-4500W WiFi Multifunctional + USB Cable A male / B male 1.80m + USB 2.0 7-port Hub Laser Printer Logo
12 questions posted
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SCX Samsung
  • SCX Samsung
Most Popular Question
multiple pages into one pdf
  • Office Equipment & Supplies
