20 Most Recent
Samsung ML-2240 Laser Printer Questions & Answers
ML 2240 printer not detected by Windows 7
Hello,Try installing it in safe mode. To go to safe mode, do the following: Restart and tap F8. Use the arrow keys to highlight safe mode with networking and hit enter. Install the driver from there and follow the on-screen instructions. If no go, check the device manager of any question mark. There might be some outdated drivers that cause this problem. You can use RadarSync (free version) to scan your computer for outdated drivers. After fixing all driver related issues, try installing the printer again. I hope this helps!David
I downloaded an update from Samsung "firmware" and
you are fucked up. REMEMBER: never upgrade your printer firmware if you want to use re-manufactured toners. You can't return to prevision version of printer firmware. You have to look for some new hacked firmware version and then everything will be OK. This firmware usually is not for free.
pifonski
ML-2245 SAMSUNG PRINTER, i AM GETTING ERROR SIGNAL
hai this is jagadish,ml-2245 printer is not getting warming up.the fuer assembly heater will get glows a few minute,and after it will get off.what is the problem!! please tell me the solution........
2240 toner replese
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.
You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.
This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.
A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
