20 Most Recent POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer Questions & Answers
I have replaced a posiflex receipt printer with a
If the print test works, then that rules out cables, etc. Definitely sounds like a comm setting issue. The most common problem with swapping serial printers is incorrect baud rate. Is that winpos from quest in Aus? I think they might use 9600 baud. You change the printer baud rate using the dipswitches under the panel on the bottom of the printer.
1/8/2014 6:54:39 AM • POS X BIXOLON... • Answered on Jan 08, 2014
How can I install Bixolon
1/8/2014 6:50:13 AM • POS X BIXOLON... • Answered on Jan 08, 2014
Why won't my Bixolong SRP-275 print the second
So it is printing the second copy, just faint? If everything is set correctly in your pos system in regards to fonts, etc, then unfortunately that sounds like a hardware problem. It could possibly be the power supply failing not supply enough current to drive the thermal head, or a main board problem, or even the thermal head might be failing. You could try cleaning the thermal head (black shiny thing you can see when you lift lid up) with isopropyl alcohol. Failing that you need a tech.
1/8/2014 6:49:30 AM • POS X BIXOLON... • Answered on Jan 08, 2014
The problem I'm having is
You could try cleaning the thermal head (the black shiny thing inside the lid that does the printing) with some isopropyl alcohol and a cotton bud. Failing that, it might need a thermal head replacement. Or you could also try printing in a larger font (if this is possible in your pos system).
1/8/2014 6:45:49 AM • POS X BIXOLON... • Answered on Jan 08, 2014
My bixolon SRP 350PLUSII is double printing one receipt, please help me how to solve it
There is no option that I know of, on the printer to do this. I suspect this is an option in the pos software that you are using. If you are using windows try doing a test print to the srp350ii from the printers in control panel and see if it prints once. I am pretty sure it will and that will prove that it is something in the software itself.
1/8/2014 6:42:23 AM • POS X BIXOLON... • Answered on Jan 08, 2014
On the printer the "paper" light turns on regardless of how big the roll of thermal paper in it is. If we open the lid then close it this will occasionally fix the problem temporarily. I have tried to
Take the paper roll out and on the left side down the bottom you will see something that looks like a small light. That is the paper low sensor. Clean the dust out of that with a microfibre cloth. Also, the lever on the left side where the paper goes in adjusts the sensitivity - try moving that up or down.
1/8/2014 6:33:41 AM • POS X BIXOLON... • Answered on Jan 08, 2014
I have a SRP350 thermal
The printer has some dipswitches under the panel on the bottom of the printer. Dipswitch 2-5 needs to be OFF and dipswitch 2-6 needs to be ON for darkest print. Default is medium. This printer is 180dpi so recommend using double size characters for darkest printing.
1/8/2014 6:25:49 AM • POS X BIXOLON... • Answered on Jan 08, 2014
0answers
Please help with the following: Printer
Looks like you'll have to contact Samsung http://www.samsungminiprinters.com
The operators manual does not give any indication about what to look for if the error light is on.
Here's what the manual states about the paper light:
This light indicates the near end of the paper roll. Install a new paper roll and the printer will continue printing. When the light blinks, it indicates the self-test printing standby state or macro execution Standby state when the macro execution command is used.
7/18/2011 6:48:05 PM • POS X BIXOLON... • Answered on Jul 18, 2011
I have bixolon srp 350
hello, im trying to send a print to my BIXOLON SRP350 Thermal printer by java codes. but java can't use the all the page width, what should i do to use all of the page width ?
4/1/2011 1:24:38 PM • POS X BIXOLON... • Answered on Apr 01, 2011
4answers
Now go to Add priinter device then remove all printer driver and go to control panel then device manager then go to printer unistall all printer device right click on it then remove all driver unplug the printer data cable from your pc then restart your pc after restart your pc then plug the data cable of your printer install printer driver from your printer cd software go to run choose setup install printer driver which printer do you want to use then restart you pc then try for print.
Thanks
Tony
Please vote me
1/15/2011 12:54:50 AM • POS X BIXOLON... • Answered on Jan 15, 2011
Samsung bixolon SRP350plus is printing hazy
Thermal heads wear out over time as the paper grates down the thermal head. You'll get to a point where the only thing you can do is to replace the head. Contact the manufacturer or service centers to where you can buy one
10/1/2010 7:37:43 PM • POS X BIXOLON... • Answered on Oct 01, 2010
My bixolon samsung srp 350plus printer will not
Try to push just the FEED button. if it doesnt feed, call their service center. hope it is in warranty still.
Problem could have happened with a power surge
5/14/2010 8:13:43 PM • POS X BIXOLON... • Answered on May 14, 2010
Computer dsplays an out of paper error. Printer
You'll need to provide more info. Where in the computer does it display out of paper error? Is it in the printer driver? or from your software/application? From what i understand this printer's windows driver cannot provide paper out status. Only its OPOS driver can. If you are using the OPOS driver, use the check health option to make sure it prints ok.
5/14/2010 8:09:46 PM • POS X BIXOLON... • Answered on May 14, 2010
POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer Logo
28 questions posted
Top POS X Office Equipment & Supplies Experts
Marvin
Marvin
Are you a POS X Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • POS X Office Equipment & Supplies
Most Popular Question
printer paper light turns regardless
  • Office Equipment & Supplies
