20 Most Recent Printronix P7220 Matrix Printer Questions & Answers
0answers
Poor quality print. How can I perform head calibration and gap adjustment?
There is not a head calibration for this printer. There is a phasing adjustment if your print looks "shaky" or to adjust the gap you use the 2 3/32" allen screws on either side of the platen bar.With the printer powered on, press the “ONLINE” key to place the printer offline. The LCD should display “OFFLINE/CONFIG. CONTROL”. On the control panel, press the arrow up and arrow down keys at the same time to unlock the enter key. “ENTER SWITCH UNLOCKED” briefly displays.Press the arrow left key. “OFFLINE/DIAGNOSTICS” displays.Press the arrow down key. “DIAGNOSTICS/Printer Tests” displays.Press the arrow down key. “Printer Tests/Shift Recycle” displays.Press the arrow left key until “Printer Tests/Phase Printer” displays.Press “ENTER”. The display shows “Printer Tests/Phase Printer” and the test begins. The current phasing value is printed on the left of the printed pattern of all H’s. As the pattern prints, examine the H’s to verify the vertical lines are straight.If the H’s are vertically straight and you are satisfied with the print quality, press “ENTER” to stop the test and then press “CLEAR” to exit the test menu.If the H’s are not straight you will need to adjust the phasing value. Press the arrow down key. The current phase index displays.Press the arrow down key. An asterisk (*) appears next to the phase value.Press the arrow right key to increase the phase value, press the arrow left key to decrease the phase value. Then press the “ENTER” key to activate the new value as it prints. Watch the printout for the new phase value to print on the left edge of the line of H’s. Examine that line for print quality. Continue to make adjustments until you are satisfied with the print quality.When the printed pattern of H’s is acceptable, press the arrow up key twice until “Printer Tests/Phase Printer” displays.Press the “ENTER” key to stop the test.
3/17/2016 10:21:53 PM • Printronix P7220... • Answered on Mar 17, 2016
Printing barcode using font 39
The printer can get out of "phase" and the print will look shaky. These instructions are for the P5000 but the phasing process has not changed. http://themrpsolution.com/v//vspfiles/Tech%20Tips%20Q&A/Printronix/P5000_phasing.pdf
1/14/2016 9:15:30 PM • Printronix P7220... • Answered on Jan 14, 2016
Processor helted novram error3
Main PCB has failed and will need to be replaced. There are 2 styles make sure you get the same one. V5 MRP provides IT Parts Product Supplies and Services V6 MRP provides IT Parts Product Supplies and Services
7/7/2015 9:07:36 PM • Printronix P7220... • Answered on Jul 07, 2015
Clear paper jam
Need more info? is it a false paper jam ? [email protected]
2/4/2015 10:37:11 PM • Printronix P7220... • Answered on Feb 04, 2015
Setting ip address
go to host interface< network setup < select ip address & subnet mask & gatway. then save
1/8/2015 11:50:19 AM • Printronix P7220... • Answered on Jan 08, 2015
Out of paper
cancel all document from pc end restart your system
1/7/2015 10:18:01 AM • Printronix P7220... • Answered on Jan 07, 2015
Weld not detect
Hi The cartridge weld was not detected. 1.Clear the fault message. 2.If message persists, replace the cartridge. 3.If necessary, replace the weld sensor.
11/20/2014 8:36:08 AM • Printronix P7220... • Answered on Nov 20, 2014
Weld not detect
ykoymgiccohoideraqepirij0rebaq8hginreqebdyeyideraqepiru8docagicai54jwymwicaglcqwrizwqebir8bgjnbaqehhweymcebasefarizwqebir8bgjnbaqehhweymcebasefarizwqebir8bgjnbaqehhweymcebasefarizwqebir8bgjnbaqehhweymcebasefarizwqebir8xp8pkfngr0qq4oeaaaaasuvork5cyii= Like the problem is not by the user fix it. Check the ribbon, check visually all about it is good.
6/25/2014 8:59:51 PM • Printronix P7220... • Answered on Jun 25, 2014
Fault: misaligned cheque prints after 20 pages
If it gets off by a full line you have a problem in you print job. If not I've seen the tractors and spline shaft cause this issue.
12/16/2013 11:41:24 PM • Printronix P7220... • Answered on Dec 16, 2013
0answers
0answers
0answers
How to change font
the best way is go to Printronix website and download the instruction
its a bit long to explain here
11/4/2010 3:09:52 AM • Printronix P7220... • Answered on Nov 04, 2010
Printronix P7220 Matrix Printer Logo
28 questions posted
Top Printronix Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Matrix Printronix
  • Matrix Printronix
Most Popular Question
adjust printronix p7220 poor quality
  • Office Equipment & Supplies
