20 Most Recent Oki Electric Industry OKI C710dn - - color - duplex - LED - Legal, A4 - 1200 dpi x 600 dpi - up to 32 ppm /... Laser Printer Questions & Answers
Shut printer off
Press Menu and Online buttons while powering back on
Press enter to format memory
Printer will request to be powered off
Power off and then back on. It should boot past the initializing screen and be fully functional.
Oki Electric... | Answered on Mar 24, 2017
Per the technical manual - Media wrapped around the fuser error. Turn off the power. Replace the fuser....
It is possible to unravel the paper from the fuser.
Oki Electric... | Answered on Jan 29, 2015
When the image drum cartridge reaches the 90% point of its life cycle on an Oki Data laser printer, a "Change Drum" message will display on the screen. Around this time the print typically starts to become faint or starts to deteriorate. When a new drum cartridge is installed, the drum cartridge counter needs to be reset for the printer to keep track of the life cycle of the replacement.
1.Turn the printer power off. Open the top cover.
2.Press the oval switch on the operator panel. Hold the switch down. Turn the printer power on.
3.Release the oval switch when the lights on the front panel flash twice. This indicates that the drum counter has been reset. Close the printer top cover.
Oki Electric... | Answered on Feb 13, 2013
Try this:
While printer is off, hold down plus "+" and minus "-" keys then power printer on and continue to hold the + and - keys until "System Maintenance" appears on the display (you will see "please wait", "initializing", "ram check" before it appears).
When System Maintenance appears press Enter. You will be prompted for a password. The default password is "000000" (six zeroes). [Use the minus key for quicker access to the zeroes and press enter twice after the last zero to enter the menu.]
Oki Electric... | Answered on Mar 29, 2010
Check online for a fuser kit for your machine, OKI machines use a fuse installed on the new fusers that reset the count and then burn out. The fuse is Littlefuse #251-062
Oki Electric... | Answered on Feb 01, 2010
Press the STATUS button on the operator panel. This will display the toner levels on the LCD screen
It is a timeout value which works only when a job
with a specified size is received.
Oki Electric... | Answered on Dec 17, 2014
Do you mean the C5100? C510 is invalid.
Oki Electric Industry OKI C710dn - - color - duplex - LED - Legal, A4 - 1200 dpi x 600 dpi - up to 32 ppm  /... Laser Printer Logo
Popular Tags
21 questions posted
Top Oki Electric Industry Office Equipment & Supplies Experts
Harrie
Davit Mamyan
Davit Mamyan
Tom Chichester
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Oki Electric Industry Office Equipment & Supplies
Most Popular Question
reset fuser oki c710
  • Office Equipment & Supplies
