20 Most Recent Samsung SCX-4828FN All-In-One Laser Printer Questions & Answers
The best is if you deinstalate your samsung drivers from your computer, if the deinstallation is done you need to reboot your computer so All the program info are deleted, the installate the driver iser from the original samsung CD or from the samsung web site to your computer, you need to download the printer and the scanner driver and the DR. Printer from the samsung download site if you do not have the CD!
Samsung... | Answered on Aug 18, 2019
replace toner chip , reset not available
Samsung... | Answered on Feb 04, 2019
if you are talking BOUT THE EXIT IT IS IN THE UPPER LEFT BEHIND THE FUSER COVER IF YOU ARE LOOKING FROM THE BACK.
Samsung... | Answered on Jul 26, 2018
Dear
Its related to fusser assy. and smps. Mostly the thermostat of the fusser assy. fails. replacing the thermostat can over come the error. some times heating lamp fails very rare. Also Smps could not supply the voltage to the heater lamp.
Samsung... | Answered on May 10, 2018
Check the device drivers. You can go to the list and locate the printer setup area. Do an update of the drivers and see f that fixes the problem.
Samsung... | Answered on Feb 19, 2018
please disconect the printer for 5 minutes from the e-socet then conect it and try, if it still not work deinstallate the drivers and reboot the computer then installate the driver's from the samsung download site to your download folder first so they are availebl later again then installate the printer driver and the scanner driver and Dr. Printer an reboot the system again now check it should work proper now.
Samsung... | Answered on Nov 13, 2017
If the msg is " system error ". You have check fuser and LVPS
Samsung... | Answered on Feb 22, 2016
Presume that the paper sensor stopped working. If after reset it still "reuses" to recognize it has paper, you should take your printer to a repair service.
If you have some doubts about my answer, continue your quesry
Samsung... | Answered on Nov 05, 2015
Servicing or replace paper pikup parts: pikup roller , separation pads, solenoid etc
Samsung... | Answered on Aug 13, 2015
U have wrogly upgrade d the firmware.of the main board.Try with a fresh copy of original Samsung firmware.
Elase replace main board.
this problem is fuser relatated check fuser thermostat. faulty Thermostat replace it resolve problem
Samsung... | Answered on Feb 06, 2015
check the lsu unit whether it is working properly or not situated just above the toner cartridge
Samsung... | Answered on Jan 13, 2015
I would get on the internet with the PC you want to install the printer on and go to here: Web Install Agent
Make sure the printer is connected and turned on, the installer will identify the printer and install software and driver automatically.
Samsung... | Answered on Dec 17, 2014
enter tech mode by menu#1934 then data setup then clear memory then ok
Samsung... | Answered on Sep 19, 2014
PLEASE REPLACE PRINTER LSU OR HIGH VOLTAGE POWER SUPPLY
Samsung... | Answered on May 08, 2014
Samsung SCX-4828FN All-In-One Laser Printer Logo
163 questions posted
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SCX Samsung
  • SCX Samsung
Most Popular Question
error u1 2330 turn off
  • Office Equipment & Supplies
