20 Most Recent Samsung SCX4824FN Mono All-in-One Laser Printer Questions & Answers
REPLACE FUSER UNIT OR LSU
Samsung... | Answered on May 08, 2014
dirty feed tires. clean with 99% alcohol.
Samsung... | Answered on Apr 22, 2014
Fixya doesn't have any drivers for any device, the only place to get the software is at the manufacturers support site, if they don't have the needed drivers to use Linux then it likely doesn't exist.
Samsung... | Answered on Feb 10, 2012
Since it wasn't behaving like this previously, re-installing the software will solve the problem.
First, disconnect the printer from your computer. Uninstall the printer software from your control pane. After that restart the computer. Don't install the software or connect the printer yet.
Go to control panel, go to printer. You should find your printer's name/model there. Right click on the name and select delete. If you don't find the printer name, no problem. But make sure you delete all printer name that you see under Printers in control panel.
After that, restart the computer again, then you can now install the printer software afresh.
Install the software first, and after that plug in the printer. The software should direct you on the right time to plug the printer into the computer.
I hope you understand the above....
Good luck.
Samsung... | Answered on Apr 01, 2011
your computer needs to be cleaned up cc cleaner.
Samsung... | Answered on Feb 11, 2011
Have you tried Scanning? If scanning either doesn't work, then it's possible that the scanning unit (scanner lamp) is bad. Or is there any specific error shown when trying to Copy? It would be great if you can clarify. Thanks.
Samsung... | Answered on Feb 04, 2011
open the feeder cover you will see 2 rubber rollers,
if found dusty then just clean both roller with wet cloth.
Samsung... | Answered on May 18, 2010
its very easy to reset via firmware and also have reset modual install main board.
www.chipresetters.com
email: [email protected]
Jayendra Patel - +919825523201
msn:[email protected]
Samsung... | Answered on Apr 14, 2010
Yes. When removing a jam, it is never wise to "aggressively" remove the paper, as it can break switches, gears, etc. maybe any switches or gears had damanged, need replacement of that parts.
Samsung... | Answered on Feb 25, 2010
HI PLEASE CLEAN THE CCDUNIT .YOUR PRINTER CCD UNIT IS VERY LOTS OF DEST.AFTER CLEANING CCD THEY PRINT SAMSE SO REPLACE CCD UNIT WITH CABLE
Samsung SCX... | Answered on Dec 02, 2019
Samsung SCX4824FN Mono All-in-One Laser Printer Logo
29 questions posted
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SCX Samsung
  • SCX Samsung
Most Popular Question
encounter paper jam whenever try copy or
  • Office Equipment & Supplies
