20 Most Recent HP LaserJet M1005 All-In-One Printer Questions & Answers
5answers
HOW TO SET HP LASERJET
how to solve engine scanner error for hp laserjet p1005
9/23/2019 6:08:58 AM • HP LaserJet... • Answered on Sep 23, 2019
6answers
Scanner Error 12
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
6/15/2019 6:36:40 AM • HP LaserJet... • Answered on Jun 15, 2019
4answers
OPERATING SYSTEM WINDOWS 7 64
you r using another printer also so ur driver s r conflicted
1/17/2019 1:48:37 PM • HP LaserJet... • Answered on Jan 17, 2019
2answers
Scanner error 20
your scanunit's lamps frecuenci is changed you should replace the scanunit
11/17/2018 5:35:46 AM • HP LaserJet... • Answered on Nov 17, 2018
HP LaserJet M1005 initializing
disply show onely inalizing
7/16/2018 1:16:21 PM • HP LaserJet... • Answered on Jul 16, 2018
Hp laserjet m1005 initializing problem
The wizard did not successfully complete copying your picture because an error occurred. See details error information. The following problem occurred while copying picture: Unspecified error The following problem occurred while copying picture: Unspecified error
7/16/2018 1:06:22 PM • HP LaserJet... • Answered on Jul 16, 2018
3answers
Driver for HP laserjet M1005 MFP printer for
Here is the Driver and Software download page for your HP Laser Jet M1005 at hp.com:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839459&taskId=135&prodTypeId=18972&prodSeriesId=1839458&lang=en&cc=us
1. After you click on the link above, select the language for your printer driver from the drop down menu.
2. Select the version of Windows 7 you have. (either 32- bit or 64-bit)
3. Save the file to a new folder on your desktop. (It will be easy to locate after downloading it)
4. I would also download the Windows 7 Print Driver - Installation Instructions save it to the folder on your desktop and read it before you install the printer driver.
11/23/2017 5:55:25 PM • HP LaserJet... • Answered on Nov 23, 2017
4answers
It is showing Scanner Error
My Printer (HP Leaser Jet M1005 MFP) Scanner Error 12 Display in my Screen.
7/21/2016 6:47:51 PM • HP LaserJet... • Answered on Jul 21, 2016
2answers
Scanner error 12 on hp
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
11/30/2015 6:16:51 AM • HP LaserJet... • Answered on Nov 30, 2015
Initializing problum
please recheck all connection eg. scanner cable ,and power circuit.
10/14/2015 2:17:36 PM • HP LaserJet... • Answered on Oct 14, 2015
2answers
Showing display on scanner error 13
This error is triggered if the scanner is not able to determine the end stop for the scanner. Likely an electronic failure but sometimes caused by too much friction in the scanner mechanism and the motor errors out trying to move the scanner.
1/19/2015 5:43:12 PM • HP LaserJet... • Answered on Jan 19, 2015
How can i fix scanner error 20?
That is most likely damage to the scanner itself, you can power it on with the lid up and watch the scanner move back and forth, if it hangs or jitters it is pretty much not worth it to repair unless you are good with taking things apart and re assembling. Sometimes cleaning can help but the labor alone is going to cost you the same as buying a new printer.
12/22/2014 7:11:49 PM • HP LaserJet... • Answered on Dec 22, 2014
2answers
Scanner 12 error
HP LaserJet M1005 mfp is not work properly. printer show scanner error 12 ple. solution
9/4/2014 5:02:27 AM • HP LaserJet... • Answered on Sep 04, 2014
Scanning
Requires use of brain and hands
8/9/2014 12:37:19 PM • HP LaserJet... • Answered on Aug 09, 2014
Full page black
1. one of the contact not engaging to the cartridge. 2. chk with another cartrdige 3. Replace DC control board
6/12/2014 7:32:46 PM • HP LaserJet... • Answered on Jun 12, 2014
My scanner hp M1005 shows me 'scanner error 12' so what can i do?
'scanner error 12'
5/26/2014 6:36:28 AM • HP LaserJet... • Answered on May 26, 2014
HP LaserJet M1005 All-In-One Printer Logo
122 questions posted
Vinaya Kumar...
Vinaya Kumar...
Ekse
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
showing scanner error
  • Office Equipment & Supplies
