20 Most Recent Ariens MaxZoom60 60" 25HP Kohler Zero Turn Lawn Mower 2012 Model Questions & Answers
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Ariens MaxZoom60... | Answered on Aug 27, 2016
The "START" relay needs to remain energized. Could be seat switch or other. See link below for wiring diagram.
https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/ariens/zero-turn-lawn-mowers/sport-zoom/915031-000101-009999-1232-sport-zoom-12hp-b-s-32-deck/wiring-diagram
Ariens Garden | Answered on Mar 29, 2020
chances are good that your problem has something to do with the throttle control on the dash. maybe a nut can be tightened up on the levers pivot? theres nothing on the carb thats adjustable for that problem i can see
Ariens Garden | Answered on Oct 20, 2019
The last 2 digits of your code give the year it was made so 2203 it means its made in 2003
Ariens Garden | Answered on Oct 01, 2019
My best guess would be the seat switch. That’s usually what causes both conditions to shut down the engine.
Ariens Garden | Answered on Jun 15, 2019
Contact Ariens directly to request the diagram.
Ariens Garden | Answered on Jun 06, 2019
if not level or not proper adjusted it will or pulley -bearing or tensioner problem -bent blades
Ariens Garden | Answered on May 28, 2019
With the lawnmower not running engage the blades, now you can use your hand to check the amount of tension as no parts should be moving so you won't have to take a trip to the er after doing so
Ariens Garden | Answered on Apr 24, 2019
Try cycling the safety switches.
1. Turn key to RUN position (1 position CCW from START)
2. Park Brake OFF/ON
3. PTO ON/OFF
4. Steering ARMs IN/OUT
5. Rise from operator seat and drop firmly into seat
6. Attempt start
If still doesn't run then likely the "START" relay. The Ariens have an atypical safety implementation and varies significantly model to model. Please comment below with your model number and I will assist further if need be.
Ariens Garden | Answered on Apr 23, 2019
Ariens MaxZoom60 60" 25HP Kohler Zero Turn Lawn Mower 2012 Model Logo
1 questions posted
Top Ariens Garden Experts
enb54
Level 1 Expert
Mike
Superior Maintenance
Are you an Ariens Garden Expert? Answer questions, earn points and help others
View Most Popular
Ariens Garden
  • Ariens Garden
Most Popular Question
when try start 60 ariens rider all get
  • Garden
