20 Most Recent Canon PIXMA iP90v InkJet Printer Questions & Answers
Hi sandimacewe,
This means that you have a purge unit error. That's the cleaning station on the right where the printhead parks.The error you are getting is telling you that the purge unit is not giving the correct timing signal as it rotates inside 360 degrees. Therefore, something is either broken or jammed inside. If you had a paper jam and tried to forcefully pull it out, you could have pulled the internal gears out of alignment.
You will need to do some maneuvers to try to release the cartridge from its parking position. Please do not force anything. Just take it to a shop if it's hard to move.
Hope this helps.
Thank you for using FixYa.
Canon PIXMA... | Answered on Jul 11, 2011
You can download the manual from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip90v#BrochuresAndManuals
Canon PIXMA... | Answered on Jan 28, 2011
Here is a link to the software you require
http://software.canon-europe.com/products/0010458.asp
Just select the operating system and language
Canon PIXMA... | Answered on Dec 01, 2010
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
You should send it to service centre
Canon PIXMA... | Answered on May 29, 2010
Any inkjet that fits the iP90v. The two inks it used are:
Black: BCI-15
Color: BCI-16
-CompDoctor
Canon PIXMA... | Answered on Feb 17, 2010
You need to remove the top cover, battery holder,shield assembly, power connector, lift the print engine slide out the drain pack and slide in a new one. After re assembly you need to get into service mode and reset the waste ink counter. Simple when you know what you're doing, 30 to 45 minute job.
Canon PIXMA... | Answered on Dec 23, 2009
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. May color and black and white print is back!
Hope this helps.
cw
Canon PIXMA... | Answered on May 25, 2009
Try sending Canon an email through their support website. I had same problem exactly, mine is 1 year old. They sent out a replacement unit for me today. It's worth a try.
Canon PIXMA... | Answered on Mar 27, 2009
I went to the Canon web sit and found the procedure to run the self test. Go to Support and Down Loads, enter you printer type, and then type in selftest and it will show you how.
Canon PIXMA... | Answered on Mar 05, 2009
Yes. But your version of Windows could be a problem.. lemme see.. Nope, no problems:
Operating Systems:
  • Windows 10 (32bit)
  • Windows 10 (64bit)
  • Windows 8.1 (32bit)
  • Windows 8.1 (64bit)
  • Windows 8 (32bit)
  • Windows 8 (64bit)
  • Windows 7 (32bit)
  • Windows 7 (64bit)
  • Windows Vista (32bit)
  • Windows Vista (64bit)
  • Windows XP
Canon PIXMA... | Answered on Apr 21, 2020
This is an ink overuse error. It may read 5B00 and not 5800.
No real easy fix as far as I know but this video might help. Good luck! https://www.youtube.com/watch?v=0waX_GF-h7U
This video might help
Canon PIXMA... | Answered on Jan 27, 2020
i don't know. please open as much as possible to see if there is olde paper still in the machine. if clear, maybe a
flashlight would help search for something in feed tray.
if you haven't tried yet, shut off printer. unplug all printer wires. reconnect power cord then load a few sheets. push the 'Stop' button a few times. push and hold stop button down for 15 seconds. try to copy something. if it works, reconnect to computer and try printing off something from notepad as a test. if still not OK. Canon may be able to test machine over the internet. also, there may be updates to
install for your neighbour.
Canon PIXMA... | Answered on Jan 18, 2020
First, get a flashlight and check inside printer for anything in the way of the ink carriage unit.
If nothing is there, then try removing the ink cartridges and see if the problem goes away, If it does, one of the cartridges needs replacement.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Canon PIXMA... | Answered on Jan 16, 2020
Hi Rolando,
This error relates to the ink absorber being almost full. You should be able to press ok and continue (unless you've already done that in which case, the ink absorber is probably full). http://canontechsupports.blogspot.com.es/2014/09/how-to-fix-error-1702170317041715e08-in.html
Canon PIXMA... | Answered on Jan 03, 2020
Canon PIXMA iP90v InkJet Printer Logo
17 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
canon pixma ip90v self test
  • Office Equipment & Supplies
